Gravity: IR Positioning Camera For Arduino
$23.55
SKU: SEN0158
  • $23.00 2+ items
  • $22.00 5+ items
  • $19.00 10+ items
Small IR camera tracks up to four heat sources, compatible with Arduino via I2C. Ideal for robot navigation, flame sensing, and creating interactive screens.
Purchase this product and earn 236 reward points, which are tied to VIP membership program. Learn More >
Want a robot to hunt down heat objects or navigated with fire? This is a small form factor IR camera capable of tracking up to four heat/IR sources. The applications are plenty and can go from tracking of robots with IR transmitters for navigation to light barriers, determining the direction where the object is going, and working as a flame sensor or tracking heat sources. It's fully compatible with Arduino with only four wires: two for power supply and two for I2C.
This infrared positioning camera can be controlled with Arduino, AVR via I2C interface. It is able to track mobile infrared points and to transmit the data back to host. The horizontal angle of camera is 33 degrees while the vertical angle is 23 degrees. It returns up to four points at a time when identifies an object. With advantages of high resolution, high sensitivity, high accuracy, small build and light weight, this Positioning IR Camera an be widely used in robot automatic search, robot soccer game, mobile trajectory recognition.
Whats more, this IR Camera can be used in making a low cost electronic whiteboard, touch screen and virtual reality headset, as seen in Johnny Lee's TED presentation about cheap Wii remote hacks.
Warning: Make sure the user knows about the power supply either directly on the sticker on the module or/and in the manual.
real-time position tracking with arduino and processing via I2C interface
  • Tracking of robots with IR transmitters for navigation.
  • Light barriers for determine the direction where the object is going to.
  • Flame sensor, tracking of heat sources.
  • Operating voltage: 3.3-5v
  • Interface: I2C​
  • Detecting distance: 0~3m
  • Horizontal detecting angle: 33 degrees
  • Vertical detecting angel: 23 degrees
  • Dimensions: 32mm x 16mm(1.26x0.63")
  • Resolution is 128x96 pixel, with hardware image processing, which can track four objects (IR emitting or reflecting objects)
  • Positioning IR Camera  x1
2022 Top 10 Bestselling Products
Blog 2022 Top 10 Bestselling Products
Jan 11, 2023
IRCameraMidi
Blog IRCameraMidi
Aug 08, 2018
Germán.Ciselli May 07, 2025
First time buying from Dfrobot. It arrived super fast, the product was impeccable, and the packaging was very neat. Plus, the support team is friendly and answers all questions about the product! 10/10
Juan Carlos.Ortega Feb 08, 2025
Great product, works very sharp, A+++!
Chris.P Oct 19, 2023
They worked great! Used with a 4 IR system to track the position of an object in 3D space and translate that to a mouse cursor position. These cameras were easy to work with and the libraries were spot on.
