Gravity: DHT22 Temperature & Humidity Sensor
$8.90
SKU: SEN0137
  • $8.70 5+ items
  • $8.50 10+ items
  • $8.30 30+ items
DHT22 capacitive humidity sensing digital temperature and humidity module is one that contains the compound that has been calibrated digital signal output of the temperature and humidity sensors. Application of dedicated digital modules collection technology and temperature and humidity sensing technology, to ensure that the product has high reliability and excellent long-term stability.
The sensor includes capacitive sensor wet components and high-precision temperature measurement devices and is connected to a high-performance 8-bit microcontroller. The product has excellent quality, fast response, strong anti-jamming capability, and cost-effectiveness.
Standard single-bus interface, system integration quick and easy. Its small size, low power consumption, and signal transmission distance of up to 20 meters make it the best choice of all kinds of applications and even the most demanding applications.
DHT22 has higher precision and can replace the expensive imported SHT10 temperature and humidity sensor.
It can measure the environment's temperature and humidity to meet high demand.
The product has high reliability and good stability. If it's used and combined with a special sensor Arduino expansion board, it will be easily implemented the interactive effect related to the temperature and humidity perception.
Note: DHT22 digital temperature and humidity sensor is designed for analog sensor interfaces. The analog port will be used as the digital which will not occupy the original digital port of the Arduino. The lines of the sensor can transform the analog function to digital that can be used on the digital port.
DHT22 temperature sensor tutorial:
  • ESP32 Arduino: Getting temperature from a DHT22 sensor
  • ESP32 Arduino: DHT22 Minimum Sampling Period
  • ESP32 Arduino: Getting humidity measurements from a DHT22 sensor
  • ESP8266 Arduino Tutorial: Getting temperature and humidity with a DHT22 sensor
  • Type Selection of Temperature Sensors
    Gravity: I2C Non-contact IR Temperature Sensor For Arduino Gravity: Analog LM35 Temperature Sensor For Arduino Gravity: Waterproof DS18B20 Sensor Kit Gravity: DS18B20 Temperature Sensor (Arduino Compatible) Gravity: Analog High Temperature Sensor
    Name Gravity: I2C Non-contact IR Temperature Sensor For Arduino Gravity: Analog LM35 Temperature Sensor For Arduino Gravity: Waterproof DS18B20 Sensor Kit
    SKU SEN0226 DFR0023 KIT0021 DFR0024 SEN0198
    Operating Voltage 3.3V/5V 3.3V/5V 3.0V~5.5V 3.3V~5V 3.3V~5.5V
    Operating Current 2.7μA 2.7μA <3μA <3μA 2.8μA
    Operating Temperature -40℃~85℃ -40℃~150℃ -55℃~125℃ -55℃~125℃ 30℃~350°C
    Range of temperature measurement 0℃~65℃ 0℃~100℃ -55℃~125℃ -55℃~125℃ -55℃~125℃
    Precision of temperature measurement 0.01℃ 0.5℃ 0.5℃ 0.5℃ 0.5℃
    Temperature deviation ±0.5℃ ±0.5℃ ±0.5°C ±0.5℃ ±0.5℃
    Dimension 30*22(mm) 30*22(mm) 33*22(mm) 22*32(mm) 42*32*18(mm)
    Interface Gravity-I2C Gravity-analog Gravity-digital Gravity-digital Gravity-analog
    Data type Digit analog
    Digit (unibus) Digit (unibus) analog
    Price $8.80 $4.50 $8.00 $4.00 $16.00
    Brief introduction
    BMP280 Barometer sensor supports Arduino and can measure both temperature and atmospheric pressure.
    It can be applied to enhance GPS navigation & coordinate with IMU sensor to realize indoor and outdoor navigation. Compared to the last generation BMP180 barometer sensor, it has a lower power consumption, higher resolution and higher sampling frequency.
    Application: Enahnced GPS navigation (e.g. time-to-first-fix improvement, dead-reckoning, slope detection) Indoor navigation (floor detection, elevator detection) Outdoor navigation, leisure and sports applications Weather forecast Health care applications (e.g. spirometry) Vertical velocity indication (e.g. rise/sink speed)
    $A Temperature Sensor can be used to detect ambient air temperature, the output voltage is proportional to temperature. It has good linearity and high sensitivity.
    Application:Medical treatments Personal controls Industrial controls Aeronautics and astronautics.
    Waterproof temperature sensor DS18B20 is widely used in many fields, such as soil temperature measurement, hot tank temperature control etc. It supports multipoint measurement.
    Application:
    Constant temperature control Industrial system Consumer electronics Thermistors Refrigerators Barns Tanks Telecommunication rooms Power communication rooms
    Cables etc.
    A Temperature Sensor can be used to detect ambient air temperature. It can be connect to three-wire in parallel to achieve multipoint temperature measurement.
    Application: Constant temperature control Industrial system Consumer electronics Thermistors Refrigerators Barns Tanks Telecommunication rooms Power communication rooms Cables etc.
    It used a PT100 resistance type high temperature probe to measure a temperature range between 30-350°C.
    Application: Especially for high precision of temperature measurements. Medical treatments Motors Industrials Temperature counts Resistance counts
    Gravity: i2C BMP280 Barometer Sensor Infrared Thermometer Module Gravity:SHT1x Humidity and Temperature Sensor Gravity: DHT11 Temperature Humidity Sensor For Arduino DHT22 Temperature and Humidity Sensor
    Name Gravity: i2C BMP280 Barometer Sensor Infrared Thermometer Module Gravity:SHT1x Humidity and Temperature Sensor
    SKU SEN0206 SEN0093 DFR0066 DFR0067 SEN0137
    Operating Voltage 3.3V~5V 3V~5V 3.3V~5V 3.3V~5V +5V
    Operating Current 1.2mA 4mA~9mA 2μA 0.5mA~2.5mA 1.5mA
    Operating Temperature -40℃~125 ℃ -10℃~50℃ -40℃~128.8℃ 0℃~50℃ -20℃-80℃
    Range of temperature measurement -70.01℃~382.19℃ -33℃~220℃ -40℃~128.8℃ 0℃~50℃ -40℃-80℃
    Precision of temperature measurement 0.5℃ 2℃(full range) 0.5℃ 2℃
    Temperature deviation ±0.5℃ ±0.6℃ ±0.4°C ±0.1℃ ±0.5℃
    Dimension 31.5*18(mm) 12*13.7*35(mm) 32*27(mm) 22*32(mm) 22*32(mm)
    Interface Gravity-I2C Digitalx3 Gravity-2-wire digital Gravity-digital Gravity-digital
    Data type Digit Digit Digit (unibus) Digit (unibus) Digit (unibus)
    Range of humidity measurement NA NA 0-100%RH 20-90%RH 0-100%RH
    Humidity deviation NA NA ±4.5%RH ±5%RH ±2%RH
    Price $16.00 $49.00 $21.05 $5.20 $9.50
    Brief introduction
    non-contact measurement uses infra-red radiation to measure the temperature and does not require a direct touch. Additionally, this method of measurement can be read quickly and accurately. This module has a FOV of 35° Wave length 5.5um-14um
    Application: Environmental monitor
    Home automation Automobile electronics
    Airline industry
    Military
    It is a long-distance thermometer specially designed for a high sensitivity, high accuracy, low noise, and low power consumption. Wave length:5um-14um This module has a FOV of  26.6°x 2 = 53.2°
    Application:
    Medical equipment Fire alarm systems telecommunications
    It consists of 1 capacitive humidity module and 1 energy gap temperature module, perfect integration of 1 14bit A/D converter and 1 2-wire digital interface.
    CMOSens technology makes it of advantages such as low power consumption, fast response, strong anti-jamming capacity etc.
    Application:
    Medical equipment
    HVAC
    Meteorology
    Humidity regulator Dehumidifier
    Tests and measurements
    Automobile
    Automatically control
    This sensor includes a resistive element and a sense of wet NTC temperature measuring devices. It has excellent quality, fast response, anti-interference ability and high cost performance advantages. Its signal transmission distance up to 20 meters. These features make it a variety of applications and even the most demanding applications.
    Application:
    Medical equipment HVAC
    Meteorology
    Humidity regulator
    Dehumidifier Tests and measurements
    Automobile
    It contains a resistive element and a sense of wet NTC temperature module. Compared to DHT11, it has smaller humidity deviation, faster response, stronger anti-interference ability and higher cost performance
    Application:
    Meteorology Humidity regulator Dehumidifier
    Automobile Automatically control
  • Supply Voltage: 5V
  • Temperature Range:-40-80℃ / resolution0.1℃ / error <±0.5℃
  • Humidity Range: 0-100%RH /  resolution0.1%RH / error±2%RH
  • Wiring map: VCC, GND,S
  • Size: 38 x 20mm(1.50x0.79")
  • DHT22 sensor   x1
  • Analog sensor cable   x1
    Arduino Wireless Weather Station Using NRF24L01, DHT11-DHT22
    Projects Arduino Wireless Weather Station Using NRF24L01, DHT11-DHT22
    RiverTrue
    Mar 11, 2022
    Soil Humidity and Apple Homekit
    Blog Soil Humidity and Apple Homekit
    May 06, 2020
    ESP32 Tutorial Arduino: 18. Getting DHT22 sensor measurements with interrupts
    Blog ESP32 Tutorial Arduino: 18. Getting DHT22 sensor measurements with interrupts
    Jan 25, 2019
    Blog ESP8266 Arduino Tutorial: Getting temperature and humidity with a DHT22 sensor
    Jun 15, 2018
    ESP32 Arduino tutorial: Getting humidity measurements from a DHT22 sensor
    Blog ESP32 Arduino tutorial: Getting humidity measurements from a DHT22 sensor
    Apr 26, 2018
    Blog ESP32 Arduino: DHT22 Minimum Sampling Period
    Apr 26, 2018
    Iñaki.Garcia Vicen May 14, 2025
    Preciso y fiable para las mediciones
    Mike. Mar 17, 2025
    Excellent Sensor - used a few of these and never disappointed. The gravity board make sit easy to connect
    $75.00
