Gravity: DHT22 Temperature & Humidity Sensor
$8.90
SKU: SEN0137
  • $8.70 5+ items
  • $8.50 10+ items
  • $8.30 30+ items
DHT22 capacitive humidity sensing digital temperature and humidity module is one that contains the compound that has been calibrated digital signal output of the temperature and humidity sensors. Application of dedicated digital modules collection technology and temperature and humidity sensing technology, to ensure that the product has high reliability and excellent long-term stability.
The sensor includes capacitive sensor wet components and high-precision temperature measurement devices and is connected to a high-performance 8-bit microcontroller. The product has excellent quality, fast response, strong anti-jamming capability, and cost-effectiveness.
Standard single-bus interface, system integration quick and easy. Its small size, low power consumption, and signal transmission distance of up to 20 meters make it the best choice of all kinds of applications and even the most demanding applications.
DHT22 has higher precision and can replace the expensive imported SHT10 temperature and humidity sensor.
It can measure the environment's temperature and humidity to meet high demand.
The product has high reliability and good stability. If it's used and combined with a special sensor Arduino expansion board, it will be easily implemented the interactive effect related to the temperature and humidity perception.
Note: DHT22 digital temperature and humidity sensor is designed for analog sensor interfaces. The analog port will be used as the digital which will not occupy the original digital port of the Arduino. The lines of the sensor can transform the analog function to digital that can be used on the digital port.
DHT22 temperature sensor tutorial:
  • ESP32 Arduino: Getting temperature from a DHT22 sensor
  • ESP32 Arduino: DHT22 Minimum Sampling Period
  • ESP32 Arduino: Getting humidity measurements from a DHT22 sensor
  • ESP8266 Arduino Tutorial: Getting temperature and humidity with a DHT22 sensor
  • Supply Voltage: 5V
  • Temperature Range:-40-80℃ / resolution0.1℃ / error <±0.5℃
  • Humidity Range: 0-100%RH /  resolution0.1%RH / error±2%RH
  • Wiring map: VCC, GND,S
  • Size: 38 x 20mm(1.50x0.79")
  • DHT22 sensor   x1
  • Analog sensor cable   x1
    Blog ESP32 Arduino: Getting temperature from a DHT22 sensor
    Apr 20, 2018
    ESP32 Arduino tutorial: Getting humidity measurements from a DHT22 sensor
    Blog ESP32 Arduino tutorial: Getting humidity measurements from a DHT22 sensor
    Apr 26, 2018
    Blog ESP32 Arduino: DHT22 Minimum Sampling Period
    Apr 26, 2018
    Blog ESP8266 Arduino Tutorial: Getting temperature and humidity with a DHT22 sensor
    Jun 15, 2018
    ESP32 Tutorial Arduino: 18. Getting DHT22 sensor measurements with interrupts
    Blog ESP32 Tutorial Arduino: 18. Getting DHT22 sensor measurements with interrupts
    Jan 25, 2019
    Soil Humidity and Apple Homekit
    Blog Soil Humidity and Apple Homekit
    May 06, 2020
    Iñaki.Garcia Vicen May 14, 2025
    Preciso y fiable para las mediciones
    Mike. Mar 17, 2025
    Excellent Sensor - used a few of these and never disappointed. The gravity board make sit easy to connect
    $2.90
