DFPlayer - A Mini MP3 Player
$5.90
SKU: DFR0299
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.40 10+ items
Sing for the moment! DFPlayer Mini MP3 Player is a compact and powerful audio player module that can be used either as a standalone module by directly connecting power, speaker, and buttons, or incorporated into various embedded systems and DIY electronic projects. Meanwhile, DFPlayer mini standalone can be used as a stand-alone module with an attached battery, speaker, and push buttons or used in combination with an Arduino UNO or any other with RX/TX capabilities. Whether you're building your own music player or adding sound effects to your project, the DFPlayer Mini is an ideal choice.
dfrobot mp3 player application
DFRobot MP3 Player Application
DFPlayer Mini supports a maximum sampling rate of 48kHz and 24-bit DAC output, ensuring high-quality audio playback. The module seamlessly integrates hardware decoding for MP3, WAV, and WMA formats, and is also capable of supporting a maximum of 32GB TF card storage with FAT16 and FAT32 file systems through software.
Support for Customization
DFPlayer Mini MP3 player offers extensive support for customization such as hardware and interface modifications, allowing for tailored solutions that suit specific needs and requirements. You can contact our customer service: store@dfrobot.com if you have any customization needs.
MP3 Module Selection Guide
If you want to learn more about DFRobot MP3 module you can check out this blog MP3 Module Selection Guide.
  • Supports playback switching at the touch of a button
  • Support up to 32GB TF card driver
  • Support MP3, WAV, WMA audio formats
  • High support for 48KHz sample rate and 24-bit DAC output can be output to provide high-quality audio playback effect.
  • Car navigation voice broadcast;
  • Road transport inspectors, toll stations voice prompts;
  • Railway station, bus safety inspection voice prompts;
  • Electricity, communications, financial business hall voice prompts;
  • Vehicle into and out of the channel verify that the voice prompts;
  • The public security border control channel voice prompts;
  • Multi-channel voice alarm or equipment operating guide voice;
  • The electric tourist car safe driving voice notices;
  • Electromechanical equipment failure alarm;
  • Fire alarm voice prompts;
  • The automatic broadcast equipment, regular broadcast.
  • Supported sampling rates (kHz): 8/11.025/12/16/22.05/24/32/44.1/48
  • 24 -bit DAC output, support for dynamic range 90dB, SNR support 85dB
  • Fully supports FAT16, FAT32 file system, maximum support 32G of the TF card, support 32G of U disk, 64M bytes NOR FLASH
  • A variety of control modes, I/O control mode, serial mode, AD button control mode
  • Advertising sound waiting function, the music can be suspended. when advertising is over in the music continue to play
  • Audio data sorted by folder supports up to 100 folders, every folder can hold up to 255 songs
  • 30 level adjustable volume, 6 -level EQ adjustable
  • DFPlayer Mini x1
Halloween trick or treat automata with Voice Recognition module
Projects Halloween trick or treat automata with Voice Recognition module
RoniBandini
Oct 16, 2023
Arduino UNO Project
Projects Arduino UNO Project
RiverTrue
Feb 27, 2023
Blog MP3 Module Selection Guide
Mar 30, 2021
jean marie.MAHOT Aug 25, 2022
perfect to me, I have been using that ones for years with arduino nano
SPYROS.PAPAKONSTANTINOU Aug 22, 2022
Perfect product, fast delivery, Perfect cooperation, I will place orders again
Geoffrey. Feb 06, 2020
One of the best player modules around-- low cost, high bandwidth, programmable (serial line) as well as hard switches. Mini SD card reader too! Use the stereo output for best quality. Use the speaker output for mono convenience. Watch power consumption for high volume speaker output.
$79.00
