RPLIDAR A1M8-R6 - 360 Degree LiDAR Laser Range Scanner (12m)
$84.00 $99.00
SKU: DFR0315
Purchase this product and earn 840 reward points, which are tied to VIP membership program. Learn More >
RPLIDAR A1 is a low cost 360 degree 2D laser scanner (LIDAR) solution developed by SLAMTEC. The system can perform 360 degree scan within 12-meter range (6-meter range of A1M8-R4 and the belowing models). The produced 2D point cloud data can be used in mapping, localization and object/environment modeling.
RPLIDAR A1’s scanning frequency reached 5.5 hz when sampling 1450 points each round. And it can be configured up to 10 hz maximum. RPLIDAR A1 is basically a laser triangulation measurement system. It can work excellent in all kinds of indoor environment and outdoor environment without direct sunlight exposure.
RPLIDAR A1M8 - 360 Degree Laser (12m,5.5HZ)
RPLIDAR A1 is based on laser triangulation ranging principle and uses high-speed vision acquisition and processing hardware developed by Slamtec. The system measures distance data in more than 8000 times per second.
RPLIDAR A1M8 - 360 Degree Laser Triangulation Ranging Principle
360 Degree Omnidirectional Laser Range Scanning
The core of RPLIDAR A1 runs clockwise to perform a 360-degree omnidirectional laser range scanning for its surrounding environment and then generate an outline map for the environment.
RPLIDAR A1M8-R6 360-degree omnidirectional laser range scanning
The sample rate of LIDAR directly decides whether the robot can map quickly and accurately.
RPLIDAR improves the internal optical design and algorithm system to make the sample rate up to 8000 times,
Comparison under different conditions
10Hz 8000 Points                      vs                  10Hz 4000 Points                   vs                           5Hz 2000 Points
RPLIDAR A1M8 - 360 Degree Laser 10Hz 8000 Points RPLIDAR A1M8 - 360 Degree Laser 10Hz 4000 Points RPLIDAR A1M8 - 360 Degree Laser 5Hz 2000 Points
OPTMAG Original Design
Most traditional non-solid LIDARs use slip ring to transfer power and data information, however, they only have thounds of hours of life due to mechanical wearing out. Slamtec has integrated the wireless power and optical communication technology to self-design the OPTMAG technology, which breakouts the life limitation of traditional LIDAR system. It fixes the electrical connecttion failure caused by the physical wearing out so as to prolong the life-span.
RPLIDAR A1M8 - 360 Degree Laser OPTMAG Original Design
Configurable Scan Rate from 2-10Hz
Users can adjust the scan rate by alternating the motor PWM signal
RPLIDAR A1M8 - 360 Degree Laser Configurable Scan Rate from 2-10Hz
Ideal for Robot Navigation and Localization
RPLIDAR is the designed sensor for applying SLAM algorithm
RPLIDAR A1M8 - 360 Degree Laser scan rate:5.5Hz, resolution:0.2%
With the scan rate set as 5.5Hz and the resolution is 0.2% percent of the actual distance
Plug and Play
Just connecting the RPLIDAR and a computer via a micro USB cable, users can use the RPLIDAR without any coding job
RPLIDAR A1M8 - 360 Degree Laser is Plug and Play
RPLIDAR A1M8 - 360 Degree Laser Scanner Development Kit RPLIDAR A1M8 - 360 Degree Laser Scanner Development Kit
RPLIDAR A1M8-R6 - 360 Degree Laser Scanner Development Kit Review (Russian)
Getting Started with LIDAR
The Secret for a Freely Walking Robot
Matched solution for robot autonomous localization and navigation
RPLIDAR A1, as the core sensor, can quickly get the outline infomation of the environment. Integrating the RPLIDAR A1 with SLAMWARE in robot, the robot can build maps autonomously, find path in real time and avoid obstacles automatically.
RPLIDAR A1M8 - 360 Degree Laser's application for robot autonomous localization and navigation
Multi-point Touch and Man-machine Interaction
Compared with traditional technology, with infrared laser device, the RPLIDAR A1 can realize the multi-point touch on a super-large screen, which has a higher resolution, reacts quickly and resists ambient light.
RPLIDAR A1M8 - 360 Degree Laser: Robot simultaneous localization and mapping PLIDAR A1M8 - 360 Degree Laser: Environment scanning and 3D rebuilding
Robot simultaneous localization and mapping (SLAM)                   Environment scanning and 3D rebuilding
RPLIDAR A1M8 - 360 Degree Laser:  Obstacle detecting and avoiding RPLIDAR A1M8 - 360 Degree Laser: Multi-point touching and man-mechine interaction
                    Obstacle detecting and avoiding                                    Multi-point touching and man-mechine interaction
  • Model: RPLIDAR A1M8-R6
  • Distance Range: A1M8-R4 and the belowing models 0.15 - 6 m
                                       A1M8-R5 0.15-12m
  • Angular Range: 0-360 degree
  • Distance Resolution: <0.5mm
                                               <1% of the distance (All distance range)
  • Angular Resolution: ≤1 degree
  • Sample Duration: 0.125 millisecond
  • Sample Frequency: ≥ 8000Hz
  • Scan Rate: 5.5Hz
  • Weight: 170g
    Related
  • 360 Degree Laser Scanner Development Kit x1
    Discover the Power of LiDAR Technology: A Comprehensive Guide
    Blog Discover the Power of LiDAR Technology: A Comprehensive Guide
    Feb 27, 2020
    Mechanical LiDAR (Laser Radar) Selection Guide
    Blog Mechanical LiDAR (Laser Radar) Selection Guide
    Mar 13, 2020
    7 Real-World Applications of LiDAR Technology
    Blog 7 Real-World Applications of LiDAR Technology
    Apr 12, 2023
    Autonomous (LIDAR) Litter Detection Robot w/ Edge Impulse
    Projects Autonomous (LIDAR) Litter Detection Robot w/ Edge Impulse
    Kutluhan Aktar
    Nov 10, 2021
    Joseph. May 06, 2022
    Love it! It's a great entry-level device into the world of Lidar, and essential for anyone serious about making a robot!
    $16.90
