Arduino product family is a great learning platform for electronics, programming and robotics. But most projects at some point require mobility. This motor
arduino shield allows Arduino to drive two channel DC motors. It uses a L298P chip which deliveries output current up to 2A each channel. Stack up this shield on your controller and drive motors with higher power requirements. Depending on the motor of choice, you can make it fast or handle a higher payload. This
Arduino Compatible Motor Shield (2A) uses L298P chip which allow to drive two 7-12V DC motors with maximum 2A current. This shield can be directly mounted onto standard
Arduino Uno R3 e and
Arduino Mega.
Speed control is achieved through conventional PWM which can be obtained from Arduino’s PWM output Pin 10 and 11. The enable/disable function of the motor control is signalled by Arduino Digital Pin 12 and 13. The Motor shield can be powered directly from Arduino or from external power source. It is strongly encouraged to use external power supply to power the motor shield.
2x2A Motor Shield for Arduino Twin Related Projects:
How to Build A Smart Cooling Fan with Arduino?
Compatible with:
