Bluno Link - A USB Bluetooth 4.0 (BLE) Dongle
$9.90
SKU: TEL0087
  • $9.70 2+ items
  • $9.50 5+ items
  • $8.90 10+ items
Add bluetooth 4.0 to your PC, Mac directly with this USB BLE-Link. It uses the USB package which is compact and compatible with v2.1 and earlier, and also supports the latest v4.0/Bluetooth Low Energy. Now you could use this adapter to receive/transmit data.
With two USB-BLE Link users can do point-to-point wireless transparent transmission, master-slave machine setting, and wireless programming. It can also work as a PC BLE wireless programming adapter. Comaptible all DFRobot BLE series modules: i.e. Bluno - An Arduino Bluetooth 4.0 (BLE) Board, Romeo BLE (Arduino Robot Control Board with Bluetooth 4.0), etc
JavaScript display
Product Name Bluno Bee - Turn Arduino to a Bluetooth 4.0 (BLE) Ready Board
Bluetooth 2.0 Module V3 For Arduino
Bluetooth 2.0 Bee Module For Arduino
Bluetooth Adapter Mini
SKU TEL0073
TEL0026
TEL0023
TEL0087
TEL0002
BLE Chip
 TI CC2540
CSR BC417143
CSR BC417143
 TI CC2540
Frequency
2.4GHz
2.4 ~ 2.48GHz unlicensed ISM band
2.4GHz
2.4 ~ 2.48GHz FHSS
Transfer rate
1Mbps GFSK
Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
1Mbps GFSK
3Mbps
BLE protocol
V4.0
V2.0 + EDR
V2.0 + EDR
V4.0
V2.0
Modulation
GFSK
GFSK
GFSK
GFSK
FHSS
Power consumption
10.6mA average, ready mode: 8.7mA
Sensitivity
-93dBm
≤-84dBm
≤-84dBm
-93dBm
≤-84dBm
Working Voltage 3.3V
+3.5 V ~ +8 V DC and 3.3V DC/50mA
3.3V
3.3V
Operating temperature
 -40 ℃ ~ +85 ℃
-20 ℃ ~ +55 ℃
-20 ℃ ~ +55 ℃
-10 ℃ ~ +85 ℃
-20℃ ~ +55℃
Transmission distance
30m
20 ~ 30m
20 ~ 30m
10 ~ 20m
<10m
Dimension
32*22mm
40*20*13mm
32*24*9mm
32mm * 16mm
20*16*8mm
Weight (g)
10
10
12
10
10
AT command to debug the BLE
master-salve machine switch
Transparent transmission
Wireless programming
√ (Available for Bluno series)
iBeacons
BLE HID
Mobile App Control
Key Featuressupport Android and IOS applications,open source code,suitable for secondary development by the user
Compatible with APC220 communication interface, can be directly used in I/O Expansion Shield, Romeo, XBoard and etc,.
It can be plugged into the Arduino controller using the XBEE base for Bluetooth wireless control.
Standard USB interface. Support for firmware update via USB. Install Arduino UNO USB driver, default host mode.
USB2.0 standard interface. supports the native Windows Bluetooth stack.
  • Bluetooth chip: TI CC2540
  • Frequency: 2.4GHz
  • Pin Layout: Compatible with Xbee pinout
  • Transfer rate: ≤1Mbps
  • Modulation: GFSK, bluetooth low power, V4.0
  • Sensitivity: -93dB
  • Input Voltage: +3.3 DC
  • Operating temperature: -10 ℃ ~ +85 ℃
  • Transmission distance: 5~15m in free space
  • Size: 32mm * 16mm(1.26"*0.63")
  • support AT command to debug the BLE
  • support master-salve switch
  • support transparent transmission serial port
  • support bluetooth remote update the Arduino program
  • USB BLE-LINK x1
