Raspberry Pi 1 Module A+(Discontinued)
SKU: DFR0344
Discontinued
This Raspberry Pi is Discontinued Now, We recommend Raspberry Pi 3 Model B as a suitable replacement.
The Raspberry Pi Model A+ is a tiny computer board that's up and running when a keyboard, mouse, display, PSU and MicroSD card with installed OS are added.It is the low-cost variant of the Raspberry Pi. It was released to replace the original Model A in November 2014. Comparing with Model A it has below features:
  • More GPIO. The GPIO header has grown to 40 pins, while retaining the same pinout for the first 26 pins as the Model A and B.
  • Micro SD. The old friction-fit SD card socket has been replaced with a much nicer push-push micro SD version.
  • Lower power consumption. By replacing linear regulators with switching ones we’ve reduced power consumption by between 0.5W and 1W.
  • Better audio. The audio circuit incorporates a dedicated low-noise power supply.
  • Smaller, neater form factor. We’ve aligned the USB connector with the board edge, moved composite video onto the 3.5mm jack, and added four squarely-placed mounting holes. Model A+ is approximately 2cm shorter than the Model A.
We recommend the Model A+ for for embedded projects and projects which require very low power, and which do not require Ethernet or multiple USB ports.
  • Broadcom BCM2835 700MHz ARM1176JZFS processor with FPU and VideoCore IV dual-core GPU
  • GPU provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode
  • GPU is capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
  • 256MB SDRAM
  • HD 1080p video output
  • Composite video (PAL/NTSC) output
  • Stereo audio output
  • HDMI 1.3 & 1.4 video/audio socket
  • 3.5mm 4-pole audio/composite video out jack socket
  • 1 x USB 2.0 socket
  • 15-way MPI CSI-2 connector for Raspberry Pi HD video camera (775-7731)
  • 15-way Display Serial Interface connector
  • MicroSD card socket
  • Boots from MicroSD card, running a version of the Linux operating system (See Note below)
  • 40-pin header for GPIO and serial buses (compatible with Raspberry Pi Model A 26-pin header)
  • Header footprint for JTAG connector
  • Power supply: +5V @ 2A via microUSB socket
  • Dimensions: 66 x 56 x 14mm
  • Raspberry Pi 1 Module A+  x1
