DFRobot Beetle BLE - The Smallest Board Based on Arduino Uno with Bluetooth 4.0
$14.90
SKU: DFR0339
  • $14.50 2+ items
  • $14.00 5+ items
  • $13.00 10+ items
A compact development board with Bluetooth 4.0, compatible with Arduino Uno. Ideal for DIY and wearable projects, supports USB and wireless programming.
Beetle BLE (formerly known as Bluno Beetle) is a miniature development board based on the Arduino Uno prototype. Equipped with Bluetooth 4.0 (BLE), it boasts a compact design and can be programmed and code uploaded through micro USB using the Arduino IDE. Additionally, it supports Bluetooth remote programming updates, eliminating the need for complex development environments and driver installations, simplifying the development process. It is fully compatible with Bluno's commands and procedures. The board also supports Bluetooth HID and iBeacon modes. For more detailed information, you can refer to the selection guide.
Beetle BLE, as an ultra-compact development board compatible with Arduino Uno, is particularly well-suited for makers, students, and other enthusiasts. It is ideal for DIY projects, creative development in gift projects, and other designs. Due to its tiny size and sewable features, along with V-shaped gold-plated I/O interfaces for easy screw-type wire connections, it is suitable for creating wearable devices such as smart bracelets and smart clothing. Additionally, it can be utilized through Bluetooth 4.0, paired with the Play Bluno application on iOS or Android, enabling remote control of devices and Arduino program updates.
Just like a native Arduino board, but with Bluetooth 4.0. An APP called Play Bluno is available on IOS and Android which gives quick access to this little tiny board.
It not only supports USB programming but also wireless uploading method. With the V-shaped gilded I/O interface, it is convenient to screw conductor wire on it, which could be a good choice in the wearable market.
Beetle BLE can be optionally paired with the Beetle BLE Expansion Board, providing users with convenient access to Beetle BLE port resources. This allows for the direct connection of DFRobot 3-pin sensors and other expansion devices. By combining the expansion board with sensors and following the basic Arduino usage tutorials for the respective sensors, users can easily fulfill various requirements and achieve a wide range of applications.
Bluno Series
Introduction to Bluno Series
  • ATmega328@16MHz
  • Bluetooth Low Energy (BT 4.0)
  • Micro USB port
  • Super Compact Size
  • Support Bluetooth HID and ibeacon
  • Compatible with all DFRobot Bluno Series
  • Support Wireless Programming
  • Bluetooth Chip: CC2540
  • Sensitivity: -93dBm
  • Working Temperature: -10 ℃ ~ +85 ℃
  • Maximun Distance: 50m(1968.50")(Open field)
  • Microcontroller: ATmega328
  • Clock frequency: 16 MHz
  • Operating voltage: 5V DC
  • Input voltage: <8V (Vin < 8V)
  • Digital Pin x4
  • Analog Pin x4
  • PWM Output x2
  • UART interface x1
  • I2C interface x1
  • Micro USB interface x1
  • Power port x2
  • Size: 28.8mm X 33.1mm(1.13" x 1.30")
  • Weight: 10g
  • Beetle BLE x1
    If we can't play Pokemon Go, let’s make an AR Pikachu
    Blog If we can't play Pokemon Go, let’s make an AR Pikachu
    Sep 07, 2016
    Beetle Controller Selection Guide
    Blog Beetle Controller Selection Guide
    Mar 30, 2022
    Bluno Beetle Simple Tutorial (With Explanatory Images)
    Blog Bluno Beetle Simple Tutorial (With Explanatory Images)
    Mar 12, 2015
    Ohsoo. Aug 23, 2021
    Alfredo. Jul 07, 2020
    Una tarjeta exageradamente perfecta para la implementación en Wearables
    $14.90
