Wireless Charging Module 5V/1A
$6.90
SKU: DFR0362
  • $6.80 2+ items
  • $6.60 5+ items
  • $6.20 10+ items
Wireless charging modules uses an electromagnetic field to transfer energy between two objects. This is usually done with a charging station. Energy is sent through an inductive coupling to an electrical device, which can then use that energy to charge batteries or run the device.
This is a new wireless charging module, which could provide 5V@1A (MAX 1.2A) power output. It is using the new technology "resonant magnetic coupling, which will reduce the electricity consumption during power transmission. The transfer efficiency could arrive at 90%. It could meet your most project requests.
5V/300mA also available (Wireless Charging Module 5V/300mA)
I made a full color POV display using SPRESENSE and DotStar LED tape.
  • Stable Power Supply
  • Magnetic coupling resonance technique
  • Insulation Coil
  • Compact Design
  • Operating Voltage (Input): 5V
  • Operating Voltage (Output): 5±6%V@1A (Max: 1.2A)
  • Transmitting Terminal Size: 43mm±2mm(1.69")(Outer diameter)*20mm(0.79")(Inside diameter)*2.3mm(0.09")(Thickness)
  • Receiving Terminal Size: 43mm±2mm(1.69")(Outer diameter)*20mm(0.79")(Inside diameter)*2.3mm(0.09")(Thickness)
  • Operating Distance: 2-10mm (0.08-0.39")
  • Transmitting Module  x1
  • Receiving Module  x1
Making a Wireless Power Supply for the UNIHIKER Single Board Computer
Projects Making a Wireless Power Supply for the UNIHIKER Single Board Computer
Afra
Nov 08, 2024
Yan.Nyein Aug 26, 2021
Haven't used, hopefully will be ok.
