GPS Module with Enclosure
$14.90
SKU: TEL0094
Note: Power has been merged with PPS without affecting usage.
You must have used a GPS receiver. It is easy to be found in most places, such as smartphones, cars, and computers. They are used to track your location all over the globe.
GPS Receiver for Arduino is a unit embedding GPS module and antenna in a small foot-print enclosure. By using the TinyGPS library, Arduino can retrieve geographic coordinates (latitude and longitude, altitude), speed, heading, and GMT time.
The update rate is an important performance index of a GPS receiver. Most GPS in mobile phones provide an update rate of 1Hz, which means, only one set of data can be retrieved in one second. For GPS receivers with 1~10Hz, the data interval is much reduced and thus can be used for more demanding applications (e.g. on fast-moving vehicles).
GPS Module with Enclosure Projects:
How to make a GPS Speedometer?
Hardware components:
  • UBX-G7020-KT solution
  • 1Hz(default) ~ 10Hz output
  • 9600bps(default) [support:4800, 9600, 19200, 38400, 57600, 115200, 230400, 460800, 921600] TTL serial interface
  • 5v @ 30mA (support 3.3~5v)
  • 56-Channel receiver
  • Extremely high sensitivity -161dBm
  • Accuracy 2.5m (Autonomous) / <2m[SBAS]
  • Operating temperature: -40°C to 85°C
  • Hot Start: 1s
  • Warm Start: 28s
  • Cold Start: 29s
  • Module Size 28*28*8.6mm (1.10*1.10*0.34")
  • Enclosure Size 37x48x16mm(1.46x1.89x0.63")
  • LED indicator
Pin Definition:
  • White:PPS
  • Red:VCC
  • Blue:TXD
  • Green:RXD
  • Black:GND
  • Yellow:EN
  • GPS Receiver for Arduino(Model) x1
  • Enclosure x1
  • Cable x1
DIY LattePanda Time Server
Blog DIY LattePanda Time Server
Feb 07, 2018
Ionizing Radiation Detector
Projects Ionizing Radiation Detector
KGray
Jun 25, 2024
Live Sailboat Monitoring over LoRa
Projects Live Sailboat Monitoring over LoRa
KGray
Jul 07, 2022
Jean. Aug 21, 2020
Hi, This is an outstanding deal. Material received 3 days after ordering from China ! All the 5 items were tested and found OK. Great job ! ON4JLV - Belgium
