Gravity: Analog Triple Axis Accelerometer MMA7260 (Discontinued)
SKU: DFR0068
Discontinued
NOTE: This product will be replaced by Triple Axis Accelerometer MMA7361
The MMA7260Q from Freescale is a very nice sensor with easy analog interface. The MMA7260QT is a 3.3V part and outputs an analog voltage for each of the three outputs. This voltage is in ratio to the measured acceleration and to the supply voltage (ratiometric). It has selectable sensitivity by dip switch.  You will need some extra hardware to convert this analog signal to a usable digital one.  The Arduino is really good option for it.  This break board is especially designed for Arduino which has 3 JST connector that can be easily plug into our IO/Sensor expansion board.
  • Voltage:3.3-8V
  • Selectable sensitivity:±1.5g/2g/4g/6g
  • Low power:500μA @ measurement mode,3μA @standby ;
  • High sensivity: 800 mV/g @ 1.5g;
  • Low pass filter
  • Size:23x26mm
  • Weight: 5 gram
