Particle Photon Development Board (Support WiFi & BLE)
$19.00
SKU: DFR0373
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
The Photon 2 is a development module with a microcontroller and Wi-Fi networking. The form-factor is similar to the Argon (Adafruit Feather), but the Photon 2 supports 2.4 GHz and 5 GHz Wi-Fi, BLE, and has much larger RAM and flash that can support larger applications.
It is intended to replace both the Photon and Argon modules. It contains the same module as the P2, making it easier to migrate from a pin-based development module to a SMD mass-production module if desired.
  • 802.11a/b/g/n Wi-Fi, 2.4 GHz and 5 GHz
          Integrated PCB antenna
          Integrated U.FL connector for external antenna
          Integrated RF switch
  • BLE 5 using same antenna as Wi-Fi
  • Realtek RTL8721DM MCU
          ARM Cortex M33 CPU, 200 MHz
  • 2048 KB (2 MB) user application maximum size
  • 3072 KB (3 MB) of RAM available to user applications
  • 2 MB flash file system
  • FCC, IC, and CE certified
  • Photon 2 Development board x1
Hamzah.Awan Mar 29, 2025
Particle boards are love
Ohsoo. Jan 19, 2021
$19.00
