I2C 16x2(1602) LCD Display Module for Arduino
$11.90
SKU: DFR0063
  • $11.60 2+ items
  • $11.40 5+ items
  • $11.00 10+ items
16x2 character LCD with I2C interface, adjustable contrast, and configurable address to avoid conflicts. Compatible with various Arduino models.
This LCD screen is a 16x2 character LCD display with an I2C interface. It features two rows for displaying text, with each row capable of displaying up to 16 characters. The white characters will be displayed on a blue background, providing a clear and visually appealing display.
In traditional Arduino LCD display projects, there are often limitations in terms of available pins, especially when using Arduino Uno. Additionally, wiring and connections can become quite complex. To address these issues, we introduce this I2C 16x2 Arduino LCD display, which utilizes the I2C communication interface. This means that it only requires 4 pins to connect the LCD display, including VCC, GND, SDA, and SCL. By adopting the I2C interface, we can save at least 4 digital/analog pins on the Arduino, making the project's connections simpler and more convenient.
All connectors are of the standard XH2.54 (breadboard type), allowing you to directly use jumper wires for connections. This connector type is widely used and offers ease of use and installation, providing you with more flexible connection options.
Interface diagram of 16x2 lcd module
To avoid the conflict of I2C addresses with other I2C devices, such ultrasonic sensor, IMU, accelerometers, and gyroscope, the I2C address of the module is configurable from 0x20-0x27. And its contrast can be adjusted manually. This allows you to select a suitable address based on your project requirements, ensuring that address conflicts are avoided.
Additionally, the LCD display also features adjustable contrast. By manually adjusting the contrast using a potentiometer, you can optimize the display effect based on the environment and personal preferences, ensuring that characters are clear and easily visible.
Another alternative option is I2C 20x4 Arduino LCD Display Module if more characters are required. This module boasts a larger display area, capable of simultaneously showcasing 20 rows of characters with 4 characters per line, providing you with additional space for presenting information.
Connection diagram with Arduino UNO
Last update: V1.2:
- I2C connector: VCC, GND, SCL, SDA
  • Compatible with Arduino/Genuino UNO, Leonardo, Mega, 101 (Intel Curie), Micro, Nano, Mini
  • I2C Address:0x20-0x27(0x20 default)
  • Back lit (Blue with white char color)
  • Supply voltage: 5V
  • Interface:I2C/TWI x1,Gadgeteer interface x2
  • Adjustable contrast
  • Size: 80x36x20mmz(3.1x1.4x0.7in)
  • I2C 16x2 LCD Screen (Arduino Compatible) x1
Wheels4Water : Let's paddle away through water mgmt issues
Projects Wheels4Water : Let's paddle away through water mgmt issues
RiverTrue
Feb 18, 2025
RFID Based Attendance System Using Arduino
Projects RFID Based Attendance System Using Arduino
ZacharyBruno
Jun 25, 2024
Arduino Alarm Clock using DS1307
Projects Arduino Alarm Clock using DS1307
Jainesh.Rathod
Feb 22, 2023
How To Make A Random Option Picker Using Arduino??
Projects How To Make A Random Option Picker Using Arduino??
ZacharyBruno
Aug 20, 2021
Automatic Car Parking System
Projects Automatic Car Parking System
RiverTrue
Aug 20, 2021
All in one clock
Projects All in one clock
ZacharyBruno
Aug 06, 2021
ines. Sep 16, 2020
works great
$19.90
