SPI / I2C Monochrome 60x32 0.5" OLED Display for Arduino
$15.00
SKU: DFR0376
Purchase this product and earn 150 reward points, which are tied to VIP membership program. Learn More >
OCELL is a 0.5" micro OLED display designed for Arduino and other microcontrollers. This micro OLED display is small as the grown-up's fingernail- 0.5" only. It has 450cd/m^2 screen brightness with extremely high contrast and readability; moreover, it contains 60 x 32 independent white OLED pixels that each can be separately controlled by the driver chip. This means you can display any images and words on the screen . Except this, the spontaneous light OLED display does not require a backlight, which greatly reduces the power consumption.
The Oled screen supports SPI (Default setting ) and I2C interface. You could connect it to Ardunio micro directly without doing any PCB layout by yourself, also you could wire it to any other MCUs like STM series , 51 series and so on. It is a good choice for a DIYer to make a interesting stuff by Arduino. Also it is very convenient for a pro-engineer to quickly develop and test a project which need a tiny COOL OLED display.
  • Operating Voltage: 3.3V -5V
  • PCB dimension: 17.8mm x 15.5mm (0.70*0.61")
  • Screen size: 0.5" inch (W*H: 15.30x10.20 mm)
  • Color: Monochrome (white)
  • OLED type: PM -OLEDOLED driver: LD7032
  • Pixels : 60 x 32
  • Contrast: 2000: 1
  • Communication: SPI, I2C
  • Micro Oled driver board x1
  • 0.5“ Oled Display x1
  • 5 Pin header x2
