Gravity: Waterproof DS18B20 Temperature Sensor Kit
$7.50
SKU: KIT0021
  • $7.20 3+ items
  • $6.90 5+ items
  • $6.50 10+ items
This waterproof temperature sensor kit use DS18B20 probe AS. It contains a probe with a resistor module. So it is easy to connect on the Arduino board.
The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface so that only one wire (and ground) needs to be connected from a central microprocessor. Compatible with 3.0-5.5V systems.
Check 27 Pcs Sensor Kit for Arduino to get more sensors for Arduino.
If you want to make a simple water purifier, we recommend buying together with Gravity: Analog TDS Sensor/Meter for Arduino.
  • Operating voltage: 3.0~ 5.5V
  • ±0.5°C Accuracy from -10°C to +85°C
  • Usable temperature range: -55 to 125°C (-67°F to +257°F)
  • 9 to 12-bit selectable resolution
  • Uses 1-Wire interface- requires only one digital pin for communication
  • Unique 64 bit ID burned into chip
  • Multiple sensors can share one pin
  • Temperature-limit alarm system
  • Query time is less than 750ms
  • 3 wires interface:
    • Type A
      • Red wire - VCC
      • Black wire - GND
      • Yellow wire - DATA
    • Type B
      • Red wire - VCC
      • Yellow wire - GND
      • Green wire - DATA
  • Stainless steel tube 6mm diameter by 35mm(1.34") long
  • Cable diameter: 4mm(0.16")
  • Length: 90cm(35.43")
DFRobot Best Sellers List
May 17, 2022
How to make a Wobbly Penguin Arduino Robot
Blog How to make a Wobbly Penguin Arduino Robot
Jul 18, 2017
Jul 27, 2017
Danli
Nov 08, 2024
jérémi.darien May 10, 2025
This is an amazing product
Sven.Sven Jan 08, 2025
HIDJO.Herve Mar 15, 2024
Exactly what i want thank you
$64.90
