Gravity: Analog Capacitive Corrosion Resistant Soil Moisture Sensor for Arduino / Raspberry Pi
$5.90
SKU: SEN0193
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
Capacitive soil moisture sensor provides reliable moisture measurement, features waterproof detection, and is compatible with low-voltage MCUs like Arduino.
Gravity: Capacitive Soil Moisture Sensor is ideal for environmental science courses and indoor gardening applications. Operating within a voltage range of 3.3 to 5.5V, this sensor provides an analog output of 1.2 to 2.5V, making it compatible with low-voltage MCUs, including both 3.3V and 5V logic systems, allowing for easy integration with popular platforms such as Arduino and Raspberry Pi. It features a waterproof detection area, effectively measuring soil moisture levels while resisting corrosion for reliable performance in outdoor and controlled environments. The capacitive design offers 2-3 times the lifespan of resistive sensors, ensuring long-term durability and dependable monitoring.
This detector is compatible with our 3-pin "Gravity" interface, which means it can be directly connected to the Gravity I/O Expansion Shield.
The following image shows an example project - a device that notifies you when a plant needs to be watered.
Gravity: Analog Capacitive Soil Moisture Sensor
Analog Soil Moisture Sensor Projects:
Get a text or call if your plant is getting too dry, along with a nice LCD display giving information regarding your plant's health.
Hardware Components:
Particle Photon Project 2: Annoying Soil Moisture Sensor with Photon and IFTTT Project
Never forget to water your plants again with this super annoying project. It combines visual, auditory, and textual cues that will prevent you from doing anything else until you provide your plant with much-needed hydration. A piezo buzzer constantly blares a shrill note, while a super-bright LED annoys your peripheral vision. In addition, this project will send constant texts to your phone reminding you that your plant needs to be watered. Sounds like fun, right?
Project 3: OBLOQ-IoT Module +Micro:bit IoT Flower Watering
  • Supports Gravity 3-Pin Interface
  • Analog Output
  • Gardening & Farming
  • Moisture Detection
  • Intelligent Agriculture
  • Operating Voltage: 3.3 ~ 5.5 VDC
  • Output Voltage: 1.2 ~ 2.5V
  • Interface: PH2.0-3P
  • Dimension: 98mm * 23mm (3.86in x 0.905in)
  • Weight: 15g
  • Capacitive Soil Moisture Sensor x1
  • Analog Sensor Cable x1
Gravity:Analog Capacitive Soil Moisture Sensor Review
Blog Gravity:Analog Capacitive Soil Moisture Sensor Review
Oct 25, 2016
Jan 13, 2025
PET POT
Projects PET POT
Mukesh Sankhla
Sep 09, 2023
How To Create Your Very Own Soil Moisture Sensor
Projects How To Create Your Very Own Soil Moisture Sensor
RiverTrue
Aug 27, 2021
Wireless Soil Moisture Probe with Helium and DFRobot
Blog Wireless Soil Moisture Probe with Helium and DFRobot
Aug 29, 2017
$12.90
