Gravity: Analog Turbidity Sensor for Arduino
$9.90
SKU: SEN0189
  • $9.80 2+ items
  • $9.70 5+ items
  • $9.50 10+ items
Turbidity sensor measures water quality by detecting particles via light transmittance. Features analog/digital outputs, adjustable threshold, not waterproof.
The Arduino turbidity sensor detects water quality by measuring the level of turbidity. It is able to detect suspended particles in water by measuring the light transmittance and scattering rate which changes with the amount of total suspended solids (TSS) in water. As the TTS increases, the liquid turbidity level increases. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
This Arduino turbidity sensor has both analog and digital signal output modes. You can select the mode according to the MCU as the threshold is adjustable in digital signal mode.
Turbidity sensors can be used in the measurement of water quality in rivers and streams, wastewater and effluent measurements, sediment transport research, and laboratory measurements.
Please note that the top of probe is not waterproof!
  • Operating Voltage: 5V DC
  • Operating Current: 40mA (MAX)
  • Response Time: <500ms
  • Insulation Resistance: 100M (Min)
  • Output Method: Analog/Digital
  • Analog Output: 0-4.5V
  • Digital Output: High/Low-level signal (you can adjust the threshold value by adjusting the potentiometer)
  • Operating Temperature: 5℃~90 ℃
  • Storage Temperature: -10℃~90℃
  • Weight: 30g
  • Adapter Dimensions: 38mm*28mm*10mm/1.5inches *1.1inches*0.4inches
  • Turbidity sensor adapter x1
  • Turbidity sensor probe x1
  • Turbidity sensor cable x1
  • Gravity analog sensor cable x1
Dec 28, 2019
GSM &amp; SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Projects GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Kutluhan Aktar
Mar 31, 2022
wajdi. Oct 21, 2022
Very good as description
wajdi. Oct 21, 2022
Chih.Kuo Dec 01, 2021
good. Wish it was waterproof
$85.00
