7" Capacitive Touch Panel Overlay for LattePanda V1 IPS Display
$19.00
SKU: FIT0478
  • $18.50 3+ items
  • $18.00 5+ items
  • $17.00 10+ items
Capacitive touch panel for a single-board computer, compatible with a 7" display. Features high sensitivity, 85% transmittance, 6H hardness, and quick response.
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
This is a capacitive touch panel overlay for your LatttePanda V1 single board computer (not compatible with LattePanda Alpha & Delta). Overlay the adhesive panel on your LattePanda 7" display (not included), connect the FPC connector and power the board. This gives you a high-quality user interface for your project!
FIT0478 - Display Effect
Note: We have recently released a new batch of touch panels that have a higher sensitivity. Drivers on boards manufactured after May 2016 will include the drivers pre-installed on the system.
If you have purchased an older version LattePanda but want to use the newer capacitive touch panel, you can download the V1.1 drivers below and manually install them.
PLEASE NOTE: “install.bat” must be run as an administrator to update the driver correctly.
NOT compatible with LattePanda Alpha and Delta edition
What is LattePanda?
A LattePanda is a complete Windows 10 single-board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras, and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby, and so on. Say goodbye to your bulky laptop!
  • Capacitive Touch Control
  • Transmittance:85%
  • Surface Hardness: 6H
  • Response Time: ≤16ms
  • Tapping Durability: 200,000,000 times
  • Supports LattePanda V1 (not compatible with LattePanda Alpha & Delta)
  • 10cm FPC Extension Cable
  • Dimensions: 164.0mm x 96.0mm
  • 7" Capacitive Touch Panel Overlay x 1
DIY A Steampunk Computer
Blog DIY A Steampunk Computer
Oct 31, 2016
ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
Blog ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
May 18, 2018
LattePanda + proximity sensing device
Blog LattePanda + proximity sensing device
Feb 07, 2018
Sebastian.Adonay Oct 17, 2021
Working perfect, using on a LattePanda i installed to control a CNC, makes using the machine way easier.
