RPLIDAR A2M12 - 360 Degree LiDAR Laser Range Scanner (12m)
$195.00 $229.00
SKU: DFR0445
Compact 360-degree LiDAR scanner with 4cm thickness, 16m range, quiet brushless motor, and advanced OPTMAG technology for long-lasting performance. Ideal for robots.
Purchase this product and earn 1950 reward points, which are tied to VIP membership program. Learn More >
RPLIDAR A2M12 - 360 Degree LiDAR (12m,5Hz-15Hz)
The core of RPLIDAR A2 runs clockwise to perform a 360-degree omnidirectional laser range scanning for its surrounding environment and then generate an outline map for the environment.
RPLIDAR A2M12 - 360 Degree Laser LiDAR Operating Principle
4cm Ultra-thin
With the custom special parts and the carefully designed internal mechanical system, the RPLIDAR A2 keeps its excellent performance while cut the thickness to only 4cm. It is ideal for all kinds of service robots.
RPLIDAR A2M12 - 360 Degree Laser LiDAR 4cm Ultra-thin
The sample rate of LIDAR directly decides whether the robot can map quickly and accurately.
RPLIDAR improves the internal optical design and algorithm system to make the sample rate up to 8000 times, which is the highest in the current economical LIDAR industry.
RPLIDAR A2M12 - 360 Degree Laser LiDAR Comparison under Different Conditions
360-degree laser range scanning
RPLIDAR A2M12 - 360-degree Laser Range Scanning
Low Noise, Brushless Motor New Non-contact Drive
Compared with the traditional belt drive mode, RPLIDAR A2 uses the self-designed brushless motor to reduce mechanical friction in running. Therefore, the RPLIDAR A2 can run smoothly without any noise.
RPLIDAR A2M12 - 360 Degree LiDAR Low Noise, Brushless Motor
16m/12m Range Radius
With algorithm optimization, RPLIDAR improves the range radius 16 meters, which will provide more data due to a larger environmental outline map.
RPLIDAR A2M12 - 360 Degree LiDAR Range Radius:16m/12m
OPTMAG Original Design
Most traditional non-solid LIDARs use slip ring to transfer power and data information, however, they only have thousands of hours of life due to mechanical wearing out. Slamtec has integrated wireless power and optical communication technology to self-design the OPTMAG technology, which breakouts the life limitation of the traditional LIDAR systems. It fixes the electrical connection failure caused by the physical wearing out so as to prolong the lifespan.
RPLIDAR A2M12 - 360 Degree LiDAR OPTMAG Original Design
Safety Standard
The RPLIDAR A2 system adopts low-power infrared laser light as its light source and drives it by using modulated pulse. The laser emits light in a very short time frame which can ensure its safety for humans and pets. It has already reached the Class 1 Safety Standard.
RPLIDAR A2M12 - 360 Degree LiDAR Safety Standard: Class 1
Measures Distance Data 8000 Times Per Second
RPLIDAR A2 adopts the laser triangulation ranging principle, and with a high-speed RPVision3.0 range engine, it measures distance data 8000 times per second and also has excellent performance in a long distances.
RPLIDAR A2M12 - 360 Degree LiDAR Measures Distance Data 8000 times per second
Five years ultra-long life
With brushless motor and OPTMAG technology, the RPLIDAR will work for 5 years(24 hours every day).
RPLIDAR A2M12 - 360 Degree LiDAR Five Years Life
Parameter comparison of different versions
RPLIDAR Parameter comparison of different versions
The Secret for a Freely Walking Robot
Matched solution for robot autonomous localization and navigation
RPLIDAR A2 as the core sensor, can quickly get the outline infomation of the environment.
Integrating the RPLIDAR A2 with SLAMWARE in robot, the robot can build maps,autonomously,find path in real time and avoid obstacles automatically.
RPLIDAR A2M12 - 360 Degree Laser Scanner Application: robot autonomous localization and navigation
Multi-point Touch and Man-machine Interaction
Compared with traditional technology, with infrared laser device, the RPLIDAR A2 can realize the multi-point touch on a super-large screen, which has a higher resolution, reacts quickly and resists ambient light.
RPLIDAR A2M12 Robot simultaneous localization and mapping RPLIDAR A2M12 Environment scanning and 3D rebuilding
Robot simultaneous localization and mapping (SLAM)                   Environment scanning and 3D rebuilding
RPLIDAR A2M12 Obstacle detecting and avoiding RPLIDAR A2M12 Multi-point touching and man-mechine interaction
                    Obstacle detecting and avoiding                                    Multi-point touching and man-mechine interaction
  • Model: RPLDIAR-A2M12
  • Measuring Range: 0.2m - 12m
  • Sampling Frequency: 16K
  • Rotational Speed: 10Hz(5Hz-15Hz)
  • Angular Resolution: 0.225°
  • Scan Field Flatness: ±1.5°
  • Proof Level: Class 1
  • System Voltage: 5V
  • System Current: 450mA - 600mA
  • Power Consumption: 2.25W-3W
  • Output: UART Serial(256000bps)
  • Temperature Range: 0℃-40℃
  • Angular Range: 360°
  • Range Resolution: ≤1% of the range(≤12m) ≤2% of the range (12m~16m)
  • Accuracy: 1% of the range(≤3 m)2% of the range(3-5 m) 2.5% of the range(5-25m)
  • RPLIDAR A2M12 - 360 Degree Laser Range Scanner      x1
    Discover the Power of LiDAR Technology: A Comprehensive Guide
    Blog Discover the Power of LiDAR Technology: A Comprehensive Guide
    Feb 27, 2020
    Mechanical LiDAR (Laser Radar) Selection Guide
    Blog Mechanical LiDAR (Laser Radar) Selection Guide
    Mar 13, 2020
    7 Real-World Applications of LiDAR Technology
    Blog 7 Real-World Applications of LiDAR Technology
    Apr 12, 2023
    $195.00 $229.00
