Acrylic Case for LattePanda V1 - Cooling Fan Compatible!
$7.50
SKU: FIT0474
  • $7.20 3+ items
  • $7.00 5+ items
  • $6.70 10+ items
This acrylic case is a solid enclosure for your LattePanda V1 single board computer (not compatible with LattePanda Alpha & Delta). It protects the board from ESD damage and the transparent acrylic lets you view the indicator LEDs directly. There is easy access to USB, HDMI, SD and GPIO and antenna. The design has been revised so that it can accommodate the LattePanda cooling fan kit. There is also plenty of room for mounting heatsinks to the CPU directly if you wish.
Assembly is simple and printed assembly instructions are included. The entire case assembly can be completed within an hour and requires no glue!
Please Note: LattePanda Windows 10 single board computer, cooling fan kit and heatsinks are sold separately.
Acrylic Case for LattePanda Package
What is a LattePanda?
A LattePanda is a complete Windows 10 single board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop!
  • LattePanda 2G/32GB 4G/64GB compatible (not compatible with LattePanda Alpha & Delta)
  • Material: Acrylic/PMMA
  • Glueless Assembly
  • Dimensions: 95 x 76 x 36mm / 3.78 x 2.99 x 1.42" (Assembled)
  • Weight: 124g
  • Acrylic Parts x 2
  • Assembly Instructions x 1
$7.50
