Metal DC Geared Motor - 12V 100RPM 12kg.cm
$11.90
SKU: FIT0492-B
Metal DC geared motor features pure copper coils, 50:1 metal reducer, 12V, 100RPM, 12 kg.cm torque, and weighs 210g. Designed for durability and stability.
This is a metal DC geared motor, 100% pure copper coils, high-density molecular layer, 50:1 metal reducer, small size, large torque. The maximum torque could arrive 12 kg.cm, stable and durable!
Metal DC Geared Motor - 12V 100RPM 42kg.cm Dimension
  • Rated voltage: 12 V
  • Gear reduction ratio: 50:1
  • D output shaft diameter: 6 mm
  • No-load speed: 100 RPM @ 12 v
  • No-load current: 0.17 A
  • Rated speed: 93 RPM @ 12 v
  • Current rating: 0.68 A
  • Rated torque: 7 kg.cm
  • Stall torque: 12 kg.cm
  • Stall current: 2.19 A
  • Power: 5W
  • Weight: 210 g
  • Metal DC Geared Motor - 12V 100RPM 12kg.cm  x1
    $11.90
