Turbo Metal Gear Worm Motor (12V 40RPM 8kg.cm)
$18.90
SKU: FIT0489-D
The turbo worm motor features a durable metal gearbox, self-locking shaft, PWM speed control, and 12V rating. It offers 40RPM speed and 8kg/cm torque.
The turbo metal gear worm motor uses a metal gear box for durability and a high torque output. Due to the special mechanical structure of the worm drive the motor output shaft is self locking and can not be rotated.
(From wikipedia)
This part uses a two wire connection and supports direction control as well as PWM speed control. Rated voltage is 12v and will achieve 40RPM, with a torque of 8kg/cm.
Warning: Do not stall motor for extended periods of time to avoid damage to the gearbox.
  • Operating Voltage: 6 - 15 V
  • Rated Voltage: 12V
  • No-load Speed: 40 RPM
  • No-load Current: 35 mA
  • Rated Torque: 32 RPM
  • Rated Current: 180 mA
  • Rated Torque: 2.2 kg.cm
  • Rated Power: 1.1 W
  • Stall Torque: 8 kg/cm
  • Stall Current: 1 A
  • Reduction Ratio: 1:150
  • Weight: 167 g
  • Metal Turbo Worm Gear Motor (12V 160RPM 2.2kg.cm) x1
