A Gravity Interface is adapted to allow plug&play to ease the barrier of usage. The IO sensor shield is the best option to connect this heart rate sensor with your Arduino or other microcontrollers. Besides, this sensor can also be compatible with Raspberry Pi, intel edison, joule and curie by means of 3.3V Input Voltage.
IoT Based Heart Rate Monitoring System is a very basic project on sending the pulse rate to Blynk Application and monitoring it from anywhere.
NOTE: 1. This product is NOT a professional medical device and should not be used to diagnose or treat medical conditions. 2. This sensor is designed to work when the user is not moving. If used while moving it will give inaccurate results.
Jul 07, 2020
Es muy sencillo de utilizar, sus características técnicas son geniales para la construcción de un Wearable.
