Have you ever wondered how to implement a vibration motor in your project, like you would find in a mobile phone? The latest vibration module in the DFRobot "Gravity" series will give you in-depth understanding of the principles of vibration motors. This module uses a high quality vibration motor that is the size of a coin. With this little vibration motor module, you can make some interesting Arduino projects such as an alarm, a notifier or even a vibrating robot!
To make this sensor accessible to users of all backgrounds, a three pin
Gravity interface is connected to allow plug and play usage with a range of Arduino microcontrollers. The
I/O sensor shield is also a useful accessory and will allow you to connect directly to your
Arduino. This sensor can also work at 3.3V levels which makes it compatible with
Raspberry Pi,
Intel Edison, Joule and Curie.
Project 1. How to Make a Running Heart Alarm T-shirt
A DIY heart-rate wereable in a running t-shirt that vibrates when your heart-rate is high, using DFROBOT components:
Component List:
Arduino Nano
vibration motor module for arduino
beetle- the smallest arduino
heart rate monitor sensor arduino
Gravity: Vibration Module x 1
Gravity Series PH2.0 to XH2.54 3 Pin Digital Cable x 1
