Gravity: TCS34725 RGB Color Sensor For Arduino
$7.90
SKU: SEN0212
  • $7.50 5+ items
  • $7.00 10+ items
  • $6.50 50+ items
After tens of millions of years of evolution, chameleons have formed a biological instinct where they can change the color of their skin to match their environment. This technique has enabled them to avoid detection from predators.
We have taken inspiration from nature to develop the TCS34725 I2C Color Sensor. Using optical techniques, this sensor detects colors in its surrounding environment and provides a digital return of red, green, blue (RGB) values. This enables you to then recreate the detected colors using these values.
The TCS34725 has a high sensitivity, wide dynamic range, and includes an IR blocking filter making it an ideal color sensing solution for use under varied lighting conditions. The sensor also includes four ultra-bright LEDs to allow the sensor to work without external light resources.
TCS34725 RGB Color Sensor For Arduino schematic -DFRobot
The module works via your Arduino’s I2C bus and includes PH2.0-4P and XH2.54 (breadboard) interfaces to meet a range of user scenarios.
TCS34725 RGB Color Sensor For Arduino Connection Diagram -DFRobot
DFRduino UNO R3 with Color Sensor
How to make a Bluetooth Music Player
  • Operating Voltage: 3.3-5V
  • Operating Current: 65 uA
  • Detection Range: 3 - 10 mm
  • The Clock Frequency: 0 - 400 KHZ
  • Interface: I2C
  • Temperature Range: -30℃ - + 70 ℃
  • Dimensions: 18.5 x 23 mm/ 0.73 x 0.9”
  • Weight: 12g
  • TCS34725 I2C Color Sensor For Arduino x1
  • I2C sensor cable x1
  • XH2.54-3P Pin Headers x2
  • Gravity: TCS34725 RGB Color Sensor For Arduino
