Gravity: PWM Infrared Carbon Dioxide / CO2 Sensor (400-5000 ppm)
$58.00
SKU: SEN0219
  • $55.00 3+ items
  • $52.00 5+ items
  • $49.00 10+ items
Purchase this product and earn 580 reward points, which are tied to VIP membership program. Learn More >
The concentration of carbon dioxide (0.03% usually) is related to daily life. Recently, there’s a study showing that the atmospheric CO2 content has reached 0.0385% (385 ppm) which is the highest value since 2.1 million years. The raise of atmospheric CO2 content to some extent results in global climate change. How to accurately measure carbon dioxide gas concentration is becoming a universal research topic.
DFRobot released its latest high-precision infrared Arduino CO2 sensor. The effectively measuring range is from 400 to 5000ppm. This sensor is based on non-dispersive infrared (NDIR) technology and has good selectivity and oxygen-free dependency. Besides, its service life could up to 5 years!
In addition, this Gravity: Infrared CO2 Sensor For Arduino (400~5000 ppm) is a high-performance sensor that combines technology of mature infrared absorption gas detection with precision optical circuit design as well as sophisticated circuit design. It has characteristics such as high sensitivity, high resolution, low power consumption, fast response, anti-water vapor interference, no poisoning, high stability, and long life.
This Gravity: Infrared CO2 Sensor is able to directly compatible with the DFRobot Arduino IO expansion board thanks to its external DFRobot Gravity interface. This character simplify the use of the sensor as it is plug and play and no need additional wiring.
This CO2 Sensor could be widely used in HVAC, indoor air quality monitoring, industrial process, and security protection monitoring, agriculture, and animal husbandry production process monitoring.
In addition, we also have a 0~50000 ppm wide-range infrared sensor with Gravity UART interface, Compatible with Arduino, Raspberry Pi, and other microcontrollers: Gravity: UART Infrared CO2 Sensor (0~50000ppm).
Infrared CO2 Sensor For Arduino Tutorial:
ESP32 Arduino: Using an infrared CO2 sensor
ESP32 Arduino: Temperature, humidity and CO2 concentration web server
Selection Guide
CO2 Sensor Selection Guide
Figure
SKU
SEN0159
SEN0220
SEN0219
SEN0536
Operation Voltage
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: Analog (Analog2.7~4.1V) + 3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART (0~3.3V Level)
Gravity: I2C
Measurement Principle
Electrochemistry (Solid electrolyte battery principle)
NDIR (non-dispersive infrared)
photoacoustic NDIR
Measurement Range
0~10000 ppm
0~5000 ppm
0~50000 ppm
400~5000 ppm
Accuracy
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<90s
<30s
60s
Average Power
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
0~95% RH (No condensation)
Lifespan
>1 year
>5 year
>5 year
>10 year
Dimension (PCB)
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. Large Range 2. Adjustable Alarm Threshold 3. Fast Response 4. Analog Output
1. High Accuracy 2. Long Lifespan 3. Auto Temperature Compensation 4. Water Vapor Interference Resistance 5. Ananglog Output
1. High Accuracy 2. Large Range 3. Long Lifespan 4. Auto Temperature Compensation 5. Water Vapor Interference Resistance 6.3.3V UART Output
1.CO2, temperature, and humidity, three in one 2. Small size of 32*27*8mm 3. Low power, average current<4mA
Add to Cart
  • Waterproof and anti-corrosion
  • High sensitivity
  • Low power consumption
  • Excellent stability
  • Temperature compensation
  • Excellent linear output
  • High cycle life
  • Anti-water vapor interference
  • No poisoning
  • Detection Gas: Carbon Dioxide (CO2)
  • Power Supply: 5.0±0.1V DC
  • Average Current: 40mA@5V
  • Peak Current: <125@5V
  • Output Signal: PWM
  • Preheat: 1min
  • Response Time: T90 < 120s
  • Working Temperature: -10℃~50℃
  • Working Humidity: 0~95%RH (non-condensing)
  • Detection Range: 400~5000 ppm
  • Resolution: 1ppm
  • Accuracy: ±(50ppm+5% rdg)
  • Dimension: 69×37mm/2.72×1.46"
  • Gravity: PWM Infrared Carbon Dioxide Sensor (400-5000 ppm) x1
  • Digital Sensor Cable for Arduino x1
    Blog ESP32 Arduino: Temperature, humidity and CO2 concentration web server
    Jun 11, 2018
    Gravity CO2 Sensor Selection Guide
    Blog Gravity CO2 Sensor Selection Guide
    Mar 26, 2020
    Jun 26, 2022
    Jarett.Smith Apr 04, 2025
    Easy to integrate with HomeAssistant. Works as expected!
