DFRobot DF9GMS 360 Degree Micro Servo (1.6Kg)
$3.90
SKU: SER0043
The DF9GMS is a lightweight, compact 360-degree micro servo with a plastic gear drive suitable for toys and DIY projects, operating at 4.8-6V with plug-and-play convenience.
The DFRobot DF9GMS is a 360 degree micro servo. It uses a plastic gear drive and is light and compact. It can be used for various applications and DIY products, such as toy cars, boats, windmills etc.
A 360 degree servo’s operation is more similar to a DC motor than a standard servo as only rotation direction and speed can be controlled. There is also no hardware stop inside so that the shaft can rotate freely. Compared to an ordinary DC motor, a 360-degree servo motor does not require additional motor drivers and is plug and play, compact and convenient. Arduino control methods are also the same. When the servo is operating on the 4.8 ~ 6V power supply, the torque can reach 1.2 ~ 1.6Kg x cm
DFRobot DF9GMS 360 Degree Micro Servo (1.6Kg) Dimensions
  • Operating Voltage: 4.8V~6V
  • Operating Temperature: -10℃~50℃
  • No-load Speed: 130±10RPM/min (6V), 110±10RPM/min (4.8V)
  • No-load Current: ≤200mA (6V), ≤150mA (4.8V)
  • Stall Torque: ≥1.3kg*cm (6V), ≥1.0kg*cm (4.8V)
  • Stall Current: ≤1000mA (6V), ≤800mA (4.8V)
  • Standby Current: ≤40mA (6V&4.8V)
  • Operating Angle: 360° continuous rotation
  • Signal Range: 500usec~2500usec
  • Wire Length: 250±5mm
  • Product Size: 22.6*12.2*27.3
  • Weight: 9±1g
  • DFRobot DF9GMS 360 Degree Micro Servo (1.6Kg) x1
  • Accessories x1
    How to make a Wobbly Penguin Arduino Robot
    Blog How to make a Wobbly Penguin Arduino Robot
    Jul 18, 2017
    Karim.Freytag Apr 05, 2025
    nice and small, not the simplest to use but still kinda plug and play
    kyle.benson May 10, 2023
    Very fast shipping. Thanks!
