BME280 is an environmental sensor that integrates onboard
temperature sensor, humidity sensor and barometer. The sensor is of high precision, multiple functions, and small size etc. It provides both SPI and I2C interfaces, which make it easy to make a fast prototypes. It can be widely used in environmental monitoring, story height measurement and Internet of Things (IoT) control and so on.
Gravity I2C BME280 Environmental Sensor has based on BoSCH newest MEMS sensor (Micro-Electro-Mechanical System). It is very stable to compare with other kind of sensors, especially the air pressure measurement, the offset temperature coefficient is ±1.5 Pa/K, equiv. to ±12.6 cm at 1 °C temperature change. Therefore, the stable and multi-function make BME280 become a good choice in many scenes.
Compatible with 3.3V/5V microcontrollers
Environmental monitoring: temperature, humidity and barometer
Gravity I2C interface and reserve XH2.54 SPI interface
Small size, convenient to install Applications
Context awareness, e.g. skin detection, room change detection
Home automation control (control heating, venting, air conditioning (HVAC))
Internet of things
GPS enhancement (e.g. time-to-first-fix improvement, dead reckoning, slope detection)
Indoor navigation (change of floor detection, elevator detection)
Outdoor navigation, leisure and sports applications
Weather forecast
Vertical velocity indication (rise/sink speed) Specification
Working Voltage:3.3V~5.0V
Working Current:2mA
Working Temperature:-40℃~+85℃
Temperature Measuring Range: -40℃~+85℃, resolution of 0.1℃, deviation of ±0.5℃
Humidity Measuring Range: 0~100%RH, resolution of 0.1%RH, deviation of ±2%RH
Pressure Measuring Range: 300~1100hPa
Humidity Sampling Time: 1s
Dimension: 22 * 25 mm/ 0.87 * 0.98 inches
Weight: 12g
Gravity: I2C BME280 Environmental Sensor (Temperature, Humidity, Barometer) x1
XH2.54-6pin Header x1
Gravity-4P I2C/ UART Sensor Wire x1
Projects Title: Uncharted Expedition
Steffen.Lorenz Apr 09, 2024
