Gravity: I2C VEML7700 Ambient Light Sensor (0~120Klx)
$9.90
SKU: SEN0228
  • $9.49 5+ items
  • $8.99 10+ items
  • $7.99 50+ items
VEML7700 is a high accuracy ambient light digital 16-bit resolution sensor. It includes a high sensitive photo diode, a low noise amplifier, a 16-bit A/D converter and supports an easy to use Gravity I2C interface. It outputs a digital signal directly and no need for complicated calculations. This is a more accurate and easier to use version of the simple photo resistor which only outputs a voltage that needs to be calculated in order to obtain meaningful data. The data which is output by this sensor is directly output in Lux (Lx). When objects which are lighted in homogeneous get the 1 lx luminous flux in one square meter, their light intensity is 1lx. Sometimes to take good advantage of the illuminant, you can add a reflector to the illuminant. So that there will be more luminous flux in some directions and it can increase the illumination of the target surface.
  • High Precision: 0.005 lx / ct
  • Wide Range: 0 ~ 167Klx (BH1750 is 0 ~ 65Klx)
  • Support Low-power consumption
  • Support Gravity i2C interface
  • Supply Voltage: 3.3-5V
  • Working Current: 45uA
  • Shutdown Mode: 0.5uA
  • Measuring Range: 0-120klx
  • Accuracy: 0.0036 lx / ct
  • Working Temperature: -25 ℃ ~ +85 ℃
  • Dimension: 30 × 22 (mm) /1.81 x0.866 (inches)
  • Weight: 12g
  • Gravity: I2C VEML7700 Ambient Light Sensor x1
  • Gravity I2C PH2.0-4P Cable x1
    Niu.yx
    Feb 11, 2025
    Danli
    Nov 08, 2024
    SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
    Projects SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
    Danli
    Jun 25, 2024
    Building Low-Carbon IoT Projects with Python for Smart Homes, Solar Power Generation, and Greenhouse
    Projects Building Low-Carbon IoT Projects with Python for Smart Homes, Solar Power Generation, and Greenhouse
    ZRZ.ZRZ
    Feb 04, 2024
    Design4SDGs: Build a Carbon-Neutral and Sustainable City with micro:bit
    Projects Design4SDGs: Build a Carbon-Neutral and Sustainable City with micro:bit
    Danli
    Jan 25, 2024
    Danli
    Jan 25, 2024
    $9.90
