FireBeetle is a series of low-power-consumption development hardware designed for
Internet of Things (IoT). Firebeetle ESP8266 is a development board integrated with IoT WiFi, TCP/IP, 32-bit MCU, 10-bit ADC, and multiple interfaces such as HSPI, UART, PWM, I2C, and I2S. In DTIM10, the full power consumption to maintain a WiFi connection reached 1.2mW. Equipped with 16MB outer SPI flash memory, ESP8266 is available for programs and firmware storage.
Compatible with
Arduino programming enables Firebeetle ESP8266 to lower the barrier of programming. The operator can implement Arduino programming codes directly onto ESP8266 to reduce the difficulty of operating and increase the stability of the esp8266 board.
In the programming stage, Firebeetle Board-ESP8266 supports RTOS SDK in Linux, Arduino IDE, and Micropython.
Tech Note 072 - ESP8266 and MAX30100 blood oximetry and heart-rate sensor display
NOTE: There still remain some bugs to be detected and fixed by developers. In some cases, some peripherals may not work perfectly by embedding Arduino sample codes in ESP8266. Much more functions implemented in Arduino are still under development and improvement. An alternative way is to change development tools such as RTOS and MicroPython towards a more operating-friendly experience in some conditions.
Operating Temperature: -40℃~+85℃
Operating Voltage: 3.3V
Input Voltage (limits): 3.3~5V (Lithium Battery:3.7V & USB:5V)
Microcontroller: Tensilica L106 (32-bit MCU)
Clock Speed: 80MHz (Maximum: 160MHz)
SRAM:50KB
External Flash Memory: 16MB
DC Current in the Low-Power-Consumption: 46uA
Average Operating Current: 80mA
Maximum Discharging Current: 600mA (LDO-3.3 Output)
Maximum Charging Current: 500mA
Digital Pin x10
Analog Pin x1
SPI interface x1
I2C interface x1
IR interface x1
I2S interface x1
Interface: XH2.54mm Pin (No soldering default)
In Combination of Wi-Fi MAC/ BB/RF/PA/LNA
WiFi: IEEE802.11 b/g/n (2.4 GHz~2.5 GHz), not support 5GHz WiFi
Dimension: 58 × 29(mm)Operating Temperature: -10℃~+55℃
Mounting Hole Dimension: 53 x 24(mm)
Weight: 24g
FireBeetle Board-ESP8266 ×1
18pin-2.54mm ×2
18pin-2.54mm Female Holder ×2
