7'' HDMI Display with Capacitive Touchscreen (Compatible with Raspberry Pi)
$79.00
SKU: DFR0506
  • $78.00 3+ items
  • $76.00 5+ items
  • $74.00 10+ items
A 7" HDMI capacitive touchscreen display supporting up to 5 touchpoints, compatible with Raspberry Pi, LattePanda, and other HDMI devices, powered via USB.
Purchase this product and earn 790 reward points, which are tied to VIP membership program. Learn More >
This is a 7 HDMI display with a capacitive touchscreen. It comes with a 7" LCD screen with a capacitive touch panel overlay on it. The touch panel supports up to 5 touchpoints. And it adopts DFRobot USB free-driver technology, with no special requirement for drivers. You can use it as easily as a keyboard or mouse. It can be directly plugged into a PC for touching control. In combination with an HDMI HD screen, it can turn a large PC into a tablet immediately.
7'' HDMI Display with Capacitive Touchscreen Compatible with Raspberry
The screen supports Windows, Linux, and MAC OS. It can be used on LattePanda, Raspberry Pi, and other HDMI devices. We also make some special holes to make it compatible with the Arduino screw hole. You can mount them on the back of the display directly.
7'' HDMI Display with Capacitive Touchscreen Connected with Raspberry
There is no need for an external power supply for the screen, it can be powered by a USB port and an HDMI port. The display also supports backlight adjustment. It is very convenient to adjust the backlight by a potentiometer on the back of the display.
Raspberry PI Computer | Tutorial | Raspberry PI 3 Model B+
IOT|HOME Automation | MQTT Server with Pi, LCD, and Camera
In this tutorial series, we will build a Pi hub with an MQTT broker.
Hardware needed:
 Note:
  • Please guarantee the external power supply current is above 1.5A@5V when it is driven by a raspberry pi. The lower current will reduce the touching sensitivity.
  • The package of this product only contains an HDMI adapter module for Raspberry Pi 3. If you want to use the product with Raspberry Pi 4, please click the link to buy the special cable for it
  • Operating Voltage: 5V
  • Operating Current: 160mA (with HDMI connection)
  • Maximum Operating Current: 1200mA
  • Refresh Frequency: 43Hz (not recommended 60Hz, it will not be full screen)
  • Screen Resolution: 1024x600
  • Video Interface: HDMI
  • Dimensions: 183mm x 100mm/ 7.2" x 3.93"
  • Mounting hole size: 3.1mm x 6mm
  • Weight: 328g
  • 7" HDMI Display with Capacitive Touchscreen x1
  • Raspberry Pi HDMI Adapter(A TO A) x1
  • Raspberry Pi HDMI Adapter(A TO D) x1
  • M2.5*8+6 Standoffs x8
  • M2.5*6 DK4.9 Machine Screws x8
    How to Make Dual Monitor Raspberry PI PC | World's Smallest Raspberry PI PC - Rizwan's Ideas
    Tutorial How to Make Dual Monitor Raspberry PI PC | World's Smallest Raspberry PI PC - Rizwan's Ideas
    Rizwan's Ideas
    Jan 11, 2024
    IoT AI-driven Tree Disease Identifier w/ Edge Impulse & MMS
    Projects IoT AI-driven Tree Disease Identifier w/ Edge Impulse & MMS
    Kutluhan Aktar
    Jun 18, 2024
    Install DF Robot Touch screen on 3D Printer
    Projects Install DF Robot Touch screen on 3D Printer
    Padmalaya Rawal
    Jan 09, 2024
    IoT AI-assisted Deep Algae Bloom Detector w/ Blues Wireless
    Projects IoT AI-assisted Deep Algae Bloom Detector w/ Blues Wireless
    Kutluhan Aktar
    Jan 12, 2023
    Barcode Based Nutrient Profiling and Food Labelling w/ TensorFlow
    Projects Barcode Based Nutrient Profiling and Food Labelling w/ TensorFlow
    Kutluhan Aktar
    May 26, 2021
    YouTube Video Recorder and Uploader GUI with Night Vision on Raspberry Pi
    Projects YouTube Video Recorder and Uploader GUI with Night Vision on Raspberry Pi
    Kutluhan Aktar
    Apr 07, 2021
    $24.95
