Gravity: IO Expansion & Motor Driver Shield
$16.90
SKU: DFR0502
  • $16.00 5+ items
  • $15.20 10+ items
  • $13.50 50+ items
The IO Expansion Shield integrates motor drivers and various interfaces for Arduino, enabling convenient connections and robot control with PWM speed support.
Purchase this product and earn 169 reward points, which are tied to VIP membership program. Learn More >
Gravity IO Expansion Shield with Motor Driver is a new product designed for Arduino Boards. It combines IO Expansion Shield and DC Motor Driver Shield, equipped with Gravity sensor interface and TB6612FNG dual motor driver. It also has XBee socket, I2C interface and UART port, makes the connections more convenient.
With TB6612FNG dual channel motor driver IC, the shield can drive 2x1.2A DC motors at the same time. It supports PWM speed control, each channel can output 1.2A continuous current and the peak current can reach to 3.2A. It is compatible with majority micro DC motors in the market. It is a solid choice for small intelligent robot controls, convenient and cost-effective.
  • Compatible with Arduino UNO R3 Pinmap.
  • Gravity-3Pin interface, plug & play, esay to use.
  • Integrated XBee Slot, XBee, WiFi Bee, Bluetooth Bee compatible.
  • Program download switch will avoid serial occupancy during Arduino UNO/Mega downloading.
  • 2x1.2A TB6612FNG DC motor driver (power from Vin port).
  • Digital interface: 14
  • Analog interface: 6
  • I2C interface: 2
  • SPI interface (compatible with Arduino UNO R3): 2
  • Serial port: 1
  • XBee Slot: 1
  • Output Current: 1.2A single channel continuous driving current
  • Start/ Peak Current: 2A (continuous pulse)/ 3.2A (monopoles)
  • Input Voltage: 12V (peak value)
  • Occupying Pins: D4, D5, D6, D7 (caution: the pin is occupied when control the motor)
  • Size: 68.5mm×53.3mm (2.7 inch×2.1 inch)
  • Weight: 36
    Gravity: IO Expansion & Motor Driver Shield x1
    DFRobot Motor Drive Expansion Board Selection Guide
    Blog DFRobot Motor Drive Expansion Board Selection Guide
    Dec 26, 2018
    Ohsoo. Aug 23, 2021
    $59.00
