Raspberry Pi 3 Model B+ (Discontinued)
SKU: DFR0567
Discontinued
Note: Raspberry Pi 3 Model B+ is discontinued now, we recommend Raspberry Pi 5 Single Board Computer as a suitable replacement.
The Raspberry Pi 3 Model B+ is the latest product in the Raspberry Pi 3 range, boasting a 64-bit quad-core processor running at 1.4GHz, dual-band 2.4GHz and 5GHz wireless LAN, Bluetooth 4.2/BLE, faster Ethernet, and PoE capability via a separate PoE HAT.
The dual-band wireless LAN comes with modular compliance certification, allowing the board to be designed into end products with significantly reduce on wireless LAN compliance testing, cost, and time resources. The Raspberry Pi 3 Model B+ maintains the same mechanical footprint as both the Raspberry Pi 2 Model B and the Raspberry Pi 3 Model B.
Note: DFRobot distributes the Element14 version.
In this video, we're flashing RASPBIAN to an SD Card for Raspberry Pi Model 3 B+ using Etcher.
You can easily run any of the Pi products following these 4 steps.
Raspberry PI Computer | Tutorial | Raspberry PI 3 Model B+
Raspberry Pi 3 Model B+ Commonly Used Accessories (shown in the video):
  • 3.5" TFT Touchscreen for Raspberry Pi
  • 10.1" Diagonal - 1280x800 IPS HDMI/VGA/AV Display
  • Wireless Keyboard with Touchpad for Raspberry Pi and LattePanda
  • High-Speed HDMI Cable (0.75M, Gold Plated)
  • 7'' HDMI Display with Capacitive Touchscreen
  • Raspberry Pi 3 Model B+ Tutorials:
  • Raspberry Pi 3 Raspbian: Python Hello World with IDLE
  • Raspberry Pi 3 Raspbian: Running Python from the command line
  • Raspberry Pi 3 Raspbian: Running Python scripts on IDLE
  • Raspberry Pi 3 Raspbian: Running a Flask server
  • Raspberry Pi 3: Getting the local IP address
  • Raspberry Pi 3 Raspbian: Exposing a Flask server to the local network
  • Raspberry Pi 3 Model B+ Project:
  • Make a small Auto Temp-Controlled Fan with Raspberry Pi
  • Features
  • A 1.4GHz 64-bit quad-core ARM Cortex-A53 CPU
  • Dual-band 802.11ac wireless LAN and Bluetooth 4.2
  • Faster Ethernet (Gigabit Ethernet over USB 2.0)
  • Power-over-Ethernet support (with separate PoE HAT)
  • Improved PXE network and USB mass-storage booting
  • Improved thermal management
  • Processor: Broadcom BCM2837B0, Cortex-A53 (ARMv8) 64-bit SoC @ 1.4GHz
  • Memory: 1GB LPDDR2 SDRAM
  • Power Supply: 5V/2.5A DC power input (micro USB)
  • Wireless: 2.4GHz and 5GHz IEEE 802.11.b/g/n/ac wireless LAN, Bluetooth 4.2, BLE
  • Ethernet: Gigabit Ethernet over USB 2.0 (maximum throughput 300 Mbps)
  • GPIOs: Extended 40-pin GPIO header
  • Video Output: Full-size HDMI
  • Audio Output: 4-pole stereo output and composite video port
  • USB Port: 4 USB 2.0 ports
  • CSI camera port for connecting a Raspberry Pi camera
  • DSI display port for connecting a Raspberry Pi touchscreen display
  • Micro SD port for loading your operating system and storing data
  • Power-over-Ethernet (PoE) support (requires separate PoE HAT)
  • Operating Temperature: 0~50℃
  • Dimension: 120mm x 75mm x 34mm
  • Weight: 75g
  • Raspberry Pi 3 Model B+ x1
    The Best 30 Raspberry Pi 3 Projects
    Blog The Best 30 Raspberry Pi 3 Projects
    Jan 24, 2019
    Raspberry Pi 3B+  Cover Installation Guide
    Blog Raspberry Pi 3B+ Cover Installation Guide
    Jun 12, 2018
    Install DF Robot Touch screen on 3D Printer
    Projects Install DF Robot Touch screen on 3D Printer
    Padmalaya Rawal
    Jan 09, 2024
    Christian. Jan 21, 2025
    I bought this beauty a lot of years ago and it still works like the first day. I sold it to a friend and he still uses it.
    Stan. Jul 11, 2020
    Very fast shipping and great quality product!
