DC Mini Immersible Water Pump (6V~18V)
$9.20
SKU: FIT0563
Purchase this product and earn 92 reward points, which are tied to VIP membership program. Learn More >
This immersible pump can be used to water your plants, make a fountain or waterfall, even change your fish tank water. It comes with an inlet valve, you can adjust the water inflow manually. Ang it works quietly with the sound level under 40db.
The pump has a filter inside as well as a suction cup which can help stick it to smooth surfaces tightly.
Note: This pump is intended for use UNDER the water ONLY! (Brown/Red-Positive; Blue/Black-Negative)
  • Solar products
  • Fountain, rockery
  • Air-Conditioner
  • Refrigerator
  • Refrigeration Industrial Equipment
  • Power supply: 6~18V DC,65mA-500mA
  • Interface: DC 5.5
  • Pumping head: 60-420cm
  • Capacity: 280~500L/H
  • Power range: 0.8~15W
  • Dimensions: 45x43x30mm(1.77x1.69x1.18")
  • Weight: 300g
  • Cable length: 1m (39.37")
  • Immersible Water Pump (6V~18V) x1
  • water pipe x1
    Water Cooling Wearable
    Blog Water Cooling Wearable
    Aug 20, 2018
