Solar Power Manager 5V
$7.90
SKU: DFR0559
  • $7.75 3+ items
  • $7.50 5+ items
  • $7.20 10+ items
The DFRobot Solar Power Manager series are designed for IoT projects and renewable energy projects, providing safe and high-efficiency embedded solar power management modules for makers and application engineers.
Solar Power Manager 5V is a small power and high-efficiency solar power management module designed for 5V solar panel.
It features as MPPT (Maximum Power Point Tracking) function, maximizing the efficiency of the solar panel. The module can provide up to 900mA charging current to 3.7V Li battery with USB charger or solar panel. The ON/OFF controllable DC-DC converters with 5V 1A output satisfies the needs of various solar power projects and low-power applications. The module also employs various protection functions for battery, solar panel and output, which greatly improves the stability and safety of your solar projects.
Check the brief specification for all Solar Power Manager Series Products.
Version History
V1.0: It is highly recommended to use a 3.7V lipo battery with protection circuits to improve battery safety.
V1.1(Newest): Battery (BAT IN) overcurrent and overdischarge protection is added to improve battery safety. It can be use for 3.7 lipo battery no matter it is packed with protection circuits or not.
Board Overview
Solar Power Manager 5V Board Overview
Connection Diagram
Solar Power Manager 5V Connection Diagram
Build a solar powered system
Selection Guide
Figure
SKU
DFR0559
DFR0535
DFR0580
DFR0579
Solar Power Management IC
CN3165
LTC3652
CN3767
SPV1050
Solar Input Voltage
4.4V-6V
7V-30V
15V-25V
0.5V-4V
Maximum Charge Current
900mA(Solar/USB)
2A(Solar/USB)
4A(Solar)
70mA(Solar)/100mA(USB)
Topology
Linear Regulator
DC-DC Buck
DC-DC Buck
DC-DC Boost
Battery
3.7V Lithium Battery
12V Lead-Acid Battery
MPPT
5V Fixed
9V/12V/18V Optional
Fixed 18V
75% Open Voltage
Battery Protections
Over Charge/Over Discharge/Over Current/Reverse Connection Protections
Over Charge/Over Discharge/Reverse Connection Protections
Output Protections
Short Circuit/Over Current Protections
Short Circuit/Over Current/Over Heat Protections
USB Charge IN
Yes
Yes
No
Yes
USB OUT
5V 1A
5V 1.5A
5V 2.5A x2
No
Regulated OUT
One Regulated Output 5V 1A
Three Regulated Outputs 3.3V 1A;5V 1.5A;9V/12V 0.5A
Two Outputs 5V 5A; 12V 8A
One Regulated Output 3.3V 90mA
Dimension
33.0mm×63.0mm
78.0mm×68.0mm
68.0mm×68.0mm
30.0mm×30.0mm
A small and easy-to-use 5V solar power management module. Applications: Solar Power Bank, Solar Environment Monitors For 5V Solar Panels within 10W
A complete multifunction solar power management module. Applications: Small Solar Street Lamp, Solar Powered Robots For 9V/12V/18V Solar Panels within20w
A medium power solar management module for 12V lead-acid batteries. Applications: Street lighting, intelligent agriculture, environmental monitoring station, UPS For 18V Solar Panels within 100W
A micro power solar power management module for low-power sensors and controllers. Applications: Wireless Sensor Network, BLE iBecon For 1V/2V/3V Solar Panels within 0.5W
Add to Cart
  • Constant voltage MPPT algorithm, maximizing solar panel efficiency
  • Designed for 5V solar panel
  • Double charging mode: solar/USB charger (900mA max charge current)
  • 5V ON/OFF controllable regulated power supply for low-power applications
  • All-round protection functions
  • USB connector with ESD shell
  • Smart solar environment monitor system
  • Solar powered robot
  • Small solar street lamp
  • Solar power bank
  • Solar Power Management IC: CN3165
  • Solar Input Voltage (SOLAR IN): 4.5V~6V
  • Battery Input (BAT IN): 3.7V Single cell Li-polymer/Li-ion Battery
  • Charge Current(USB/SOLAR IN): 900mA Max trickle charging, constant current, constant voltage three phases charging
  • Charging Cutoff Voltage (USB/SOLAR IN): 4.2V±1%
  • Regulated Power Supply: 5V 1A
  • Regulated Power Supply Efficiency (3.7V BAT IN): 86%@50%Load
  • USB/Solar Charge Efficiency: 73%@3.7V 900mA BAT IN
  • Quiescent Current: <1 mA
  • Operation Temperature: -40℃~85℃
  • Dimension: 33.0mm*63.0mm
  • Protection Functions:
  1. BAT IN: over charge/over discharge/over current/reverse connection protection
  2. 5V/USB OUT: short circuit/over current/over heat protection
  3. SOLAR IN: reverse connection protection
  • Solar Power Manager 5V x1
  • 2.54mm Black Jumper x1
  • M3*10mm Nylon Pillar x4
  • M3*5mm Stainless Steel Screw x4
  • 14*14*7mm Black Aluminum Cooling Fin x1
  • 14*14*0.5mm Thermal Conductive Silicone Pad x1
2022 Top 10 Bestselling Products
Blog 2022 Top 10 Bestselling Products
Jan 11, 2023
Frances
Oct 25, 2021
Jacob.Cathey Jan 19, 2022
Surprisingly this power manager is heavier than I expected, very well crafted and has been consistent in its output since my purchase. Getting creative I have found a wide range of applications I can use it in. From a rechargeable porch light to a countertop dual (x2) 18650 battery charger.
Iñaki.Garcia Vicen May 14, 2025
Recomendable, perfecto para alimentar RBP o ESP32
Charles.Warinner Mar 04, 2025
Shipping was fast and the packaging is nice! When you usually buy this type thing from other vendors it’s usually a plain esd bag, but they put some time and effort into the presentation and was a nice surprise. Haven’t tested yet but looks great! Happy about finding out about this company!
$15.50
