micro:Driver - Driver Expansion Board for micro:bit / UNIHIKER M10 / K10
$11.90
SKU: DFR0548
  • $11.50 3+ items
  • $10.90 5+ items
  • $10.50 10+ items
Since the advent of micro:bit, its simple and practical way of programming is widely loved by makers, students and teachers. Its sample design, coupled with a wealth of pin resources, give it infinite possibilities. This expansion board not only leads to 9 micro:bit onboard GPIO interfaces, but also comes with 4-way motor drives and 8 servo interfaces, of which 4-way motor drives can be reused as 2-way stepper motor drives.
Micro:bit Driver Expansion Board adopts I2C external drive chip to control the motor and servo motor, only takes up two I2C pins and can complete the motor and servo dual control without occupying other resources. Using HR8833 motor driver, the maximum continuous operating current is 1.5A, it can drive the ordinary small motor and N20 mini metal motor. Each motor port comes with a positive and negative rotating indicator to identify the motor running direction conveniently, which is very suitable for students and makers to make small projects. Both the extended GPIO and the servo interface use the DFRobot-Gravity standard interface, supporting a large number of modules and sensors. The servo interface is directly connected to the Vin power supply, thus increasing the supply current which can support multiple servos to work at the same time.
This expansion board supports 3.5V to 5.5V power supply. It provides a DC 2.1 plug and a wiring terminal which can be connected directly to three dry battery boxes. It comes with a USB to DC 2.1 adapter cable, which can be powered by power bank and is more economical and environment-friendly.
JavaScript display
Motor Drive Expansion Board Selection Guide
Product Name 2x1A DC Motor Shield for Arduino
Gravity: Dual Bipolar Stepper Motor Shield for Arduino (DRV8825)
Quad DC Motor Driver Shield for Arduino
SKU DRI0001
DFR0548
DRI0023
DRI0039
Chip
L293B
HR8833
DRV8825
TB6612FNG
Operating voltage
5V DC / 3.3V/5V 2.7~5.5V
Motor drive voltage7-12V DC
3.5~5.5V DC
8.2-45VDC2.5V-13.5V
Maximum drive current
1A each way 1.5A 1.6A
1.2A continuous current (per channel)
2A (continuous pulse)
3.2A (single pulse)
Motor drive using pins
PIN4/5/6/7 (Arduino Controllor)
D4,D5,D6
D7,D8,D12
D3,4,5,6,7,8,11,12
Dimension
56x57mm
63 x 58mm
83*55*25mm
 52mm * 53mm
Weight (g)
60 64 48 24
Frequently used With
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
With motor indicator
8-way servo interface
DC motor x4/stepper motor x2(multiplexed with motor interface)
Full step, 1/2, 1/4, 1/8, 1/16, 1/32 step mode
High-speed drive capability, can drive ordinary 2-phase stepper motor to 5000RPM, and drive quad DC at the same time
Product Name Gravity: IO Expansion & Motor Driver Shield
Gravity: 2x2A Motor Shield for Arduino Twin
TMC260 Stepper Motor Driver Shield
2x2A DC Motor Shield for Arduino
SKU DFR0502
DRI0017
DRI0035
DRI0009
Chip
TB6612FNG
L298
TMC260
L298P
Operating voltage
2.7~5.5V
5V 5V
5V
Motor drive voltage12V (peak value)
4.8 ~ 35V
40V max
6.5~12v(VIN Power Supply),4.8~35V (External Power Source)
3.2A (single pulse)
up to 2A/channel
up to 2A per motor coil
2A
D4 D5 D6 D7
D10,11,12,13
/ Pin 4,5,6,7 are used to drive two DC motor
Dimension
68.5mm×53.3mm
56x57mm
55x55mm
Weight (g)
36 35 35 60
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
Integrated XBee Slot, XBee, WiFi Bee, Bluetooth Bee,  IIC.
Mirrored version of DRI0009.
Drive pins: 10, 11, 12, 13
Not compatible with IO expansion board V7.1. The control port is four, which reduces the overhead of the Arduino digital ports, and easy to program.
Suitable for driving bipolar stepper motors.
SPI serial bus control or STEP/DIR signal control.
Controllers such as Mega with full port expansion.
256 times microstep subdivision.
Use mirror motor to drive DRI0017 to aviod the conflicts . Support PWM speed control. Support PLL advance speed control
  • Digital Output Voltage: 0V / 3.3V
  • Analog Output Voltage: 0~3.3V DC
  • Standard Gravity Interface
  • Micro: bit Interface: 9 (P0 P1 P2 P8 P12 P13 P14 P15 P16)
  • Servo Interfaces x 8
  • Motor Interface: DC Motor x 4 / Step Motor x 2
  • Dimension: 63x58mm / 2.48x2.28in
  • Micro:bit Driver Expansion Board x1
  • USB to DC2.1 converter cable x1
    Pan-Tilt Playground: Part 5 - Hand gesture controller
    Projects Pan-Tilt Playground: Part 5 - Hand gesture controller
    Lupin
    Mar 11, 2025
    Simple radar with Python
    Projects Simple radar with Python
    Lupin
    Feb 22, 2024
    How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Projects How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Afra
    Dec 06, 2023
    Steffen.Lorenz Apr 09, 2024
    I tested everything with UNIHIKER / Python and found absolutely no problems. Code, execute and enjoy is the motto here!
    jeevantha.Devapriya Sep 14, 2023
    perfect processing thank you very much
    Damjan. Oct 28, 2022
    Nice addition to any micro:bit board. A lot of connectors for all sorts of things.
