DFRobot's latest generation of digital DHT11 Temperature and Humidity sensor is as powerful as it used to be but easier to use. This DHT11
Arduino temperature and humidity sensor has a full range temperature compensation,
low power consumption, long term stability and calibrated digital signal. A high-performance 8-bit microcontroller is integrated in the sensor with calibration-coefficient saved in OTP memory to provide accurate temperature readings.
Classic temperature and humidity sensor, low price, suitable for designs with low accuracy requirements
High-precision temperature and humidity sensor, DHT11 upgrade version, the same price but improved performance, using I2C communication, data is more stable
High-precision temperature and humidity sensor, high price, high detection range and accuracy
Add to Cart
Standard assembling struct ( two 3mm holes with multiple of 5cm as interval ).
User-friendly interfaces ( "A" for analog and "D" for digital ).
Icons to simplely illustrate sensor function.
High quality connector.
Immersion gold surface.
