Gravity: DHT11 Temperature & Humidity Sensor For Arduino
$4.20
SKU: DFR0067
Purchase this product and earn 42 reward points, which are tied to VIP membership program. Learn More >
DFRobot's latest generation of digital DHT11 Temperature and Humidity sensor is as powerful as it used to be but easier to use.  This  DHT11 Arduino temperature and humidity sensor has a full range temperature compensation, low power consumption, long term stability and calibrated digital signal. A high-performance 8-bit microcontroller is integrated in the sensor with calibration-coefficient saved in OTP memory to provide accurate temperature readings.
Gravity DHT11 Temperature Humidity Sensor For Arduino Connection
To ease the difficulty,  a Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield is the best match to connect with your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Piintel edison, joule and curie.
Temperature Sensor Tutorial: Type Selection of Temperature Sensors
Is it difficult for you to choose a temperature sensor from the maker market that is full of different kinds? Therefore, we have prepared a guide of temperature sensors that compatible with Arduino for your reference.
  • Standard assembling struct ( two 3mm holes with multiple of 5cm as interval ).
  • User-friendly interfaces ( "A" for analog and "D" for digital ).
  • Icons to simplely illustrate sensor function.
  • High quality connector.
  • Immersion gold surface.
  • Wider voltage range: 3.3V to 5V
  • Temperature range :0-50 °C error of ± 2 °C
  • Humidity :20-90% RH ± 5% RH error
  • Interface: Digital
  • Gravity: DHT11 Temperature & Humidity Sensor For Arduino x1
  • Digital sensor cable x1
    Getting Started with LattePanda
    Blog Getting Started with LattePanda
    Nov 08, 2016
    Jul 27, 2017
    Niu.yx
    Feb 11, 2025
    Voice Controlled DHT11 with DFRobot
    Projects Voice Controlled DHT11 with DFRobot
    pradeeplogu0
    Jun 06, 2024
    Danli
    Jan 10, 2024
    Smart Home Using Unihiker and NodeMcu
    Projects Smart Home Using Unihiker and NodeMcu
    Hackhobby Lab
    Jan 08, 2024
    $579.00
