Gravity: DHT11 Temperature & Humidity Sensor For Arduino
$4.20
SKU: DFR0067
Purchase this product and earn 42 reward points, which are tied to VIP membership program. Learn More >
DFRobot's latest generation of digital DHT11 Temperature and Humidity sensor is as powerful as it used to be but easier to use.  This  DHT11  Arduino  temperature and humidity sensor has a full range temperature compensation, low power consumption, long term stability and calibrated digital signal. A high-performance 8-bit microcontroller is integrated in the sensor with calibration-coefficient saved in OTP memory to provide accurate temperature readings.
Gravity DHT11 Temperature Humidity Sensor For Arduino Connection
To ease the difficulty,  a Gravity Interface is adapted to allow plug&play. The Arduino IO expansion shield is the best match to connect with your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Pi,  intel edison, joule and curie.
Selection Guide
Temperature & Humidity Sensor Selection Guide
Figure
SKU
DFR0067
SEN0497
SEN0137
Communication Method
One wire
I2C
One wire
Operating Voltage
3.3-5V
3.3-5V
5V
Temperature range ± error
0~+50 ± 2 ℃
-40~+80 ± 0.5℃
-40~+80 ± 0.5℃
Humidity range ± error
20~90% ± 5%RH
0~100% ± 3%RH
0~100% ± 2%RH
Classic temperature and humidity sensor, low price, suitable for designs with low accuracy requirements
High-precision temperature and humidity sensor, DHT11 upgrade version, the same price but improved performance, using I2C communication, data is more stable
High-precision temperature and humidity sensor, high price, high detection range and accuracy
Add to Cart
  • Standard assembling struct ( two 3mm holes with multiple of 5cm as interval ).
  • User-friendly interfaces ( "A" for analog and "D" for digital ).
  • Icons to simplely illustrate sensor function.
  • High quality connector.
  • Immersion gold surface.
  • Wider voltage range: 3.3V to 5V
  • Temperature range :0-50 °C error of ± 2 °C
  • Humidity :20-90% RH ± 5% RH error
  • Interface: Digital
  • Gravity: DHT11 Temperature & Humidity Sensor For Arduino x1
  • Digital sensor cable x1
    Getting Started with LattePanda
    Blog Getting Started with LattePanda
    Nov 08, 2016
    Jul 27, 2017
    Niu.yx
    Feb 11, 2025
    Voice Controlled DHT11 with DFRobot
    Projects Voice Controlled DHT11 with DFRobot
    pradeeplogu0
    Jun 06, 2024
    Danli
    Jan 10, 2024
    Smart Home Using Unihiker and NodeMcu
    Projects Smart Home Using Unihiker and NodeMcu
    Hackhobby Lab
    Jan 08, 2024
