40A Bidirectional Brushed ESC Speed Controller without Brake (XT60 Connector) (Discontinued)
SKU: DRI0048
Discontinued
Note: 40A Bidirectional Brushed ESC Speed Controller without Brake (XT60 Connector) is discontinued now.
ESC (Electronic Speed Controller) can be divided into brushed ESC and brushless ESC according to the different motor types. It is widely used in the RC remote control system and we can use signal to control the speed.
This is a 40A bidirectional brushed ESC without Brake. It can support up to 40A continuous current and 340A instantaneous current. It is controlled by PPM signal and can drive the forward and reverse rotation of the motor. Support RC remote controller of commonly used brands on the market.
NOTE:
    Please carefully read the product specifications before using the equipment, do not overpressure or overload.
  • Type: bidirectional brushed ESC
  • Continuous current: 40A
  • Voltage range: 7V-24V (lithium battery 2S)
  • Peak current: 340A forward, 340A backward
  • Output line: power line and motor line 16AWG-100mm
  • Control signal type: PPM
  • Power connector: XT60 banana plug
  • Motor connector: 4mm banana plug
  • Dimensions: L47mm, W37.5mm, H18.5mm (including heat sink)
  • whether waterproof? No
  • Weight: 30g
  • 40A Bidirectional Brushed ESC Speed Controller without Brake (XT60 Connector) x1
