Gravity: Lab Grade Analog pH Sensor Kit for Arduino / Raspberry Pi (With Calibration Solutions)
$39.50
SKU: SEN0161-V2
  • $37.50 3+ items
  • $35.50 5+ items
  • $33.50 10+ items
Purchase this product and earn 395 reward points, which are tied to VIP membership program. Learn More >
DFRobot Gravity: Analog pH meter V2 is specifically designed to measure the pH of the solution and reflect the acidity or alkalinity. DFRobot ph sensor is commonly used in various applications such as aquaponics, aquaculture, and environmental water testing.
As an upgraded version of pH meter V1, this product greatly improves the precision and user experience. The onboard voltage regulator chip supports the wide voltage supply of 3.3~5.5V, which is compatible with the 5V and 3.3V main control boards. The output signal filtered by hardware has low jitter. The software library adopts the two-point calibration method, and can automatically identify two standard buffer solutions (4.0 and 7.0), so simple and convenient. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
The sensor can be easily connected to most popular microcontrollers  (such as Arduino), with its Arduino library, you can quickly build a pH meter, plug and play. DFRobot provides a variety of water quality ph analog sensor products, uniform size, and interface, not only meeting the needs of various water quality measuring  but are also suitable for the DIY multi-parameter water quality tester.
The pH is a value that measures the acidity or alkalinity of the solution. It is also called the hydrogen ion concentration index. The pH is a scale of hydrogen ion activity in the solution. The pH has a wide range of uses in medicine, chemistry, and agriculture. Usually, the pH is a number between 0 to 14. Under the thermodynamic standard conditions, pH=7, which means the solution is neutral; pH<7, which means the solution is acidic; pH>7, which means the solution is alkaline.
SEN0161-V2-Arduino Connection Diagram
   Attention:
1. The BNC connector and the signal conversion board must be kept dry and clean, otherwise, it will affect the input impedance, resulting in an inaccurate measurement. If it is damp, it needs to be dried.
2. The signal conversion board cannot be directly placed on a wet or semiconductor surface, otherwise, it will affect the input impedance, resulting in an inaccurate measurement. It is recommended to use the nylon pillar to fix the signal conversion board, and allow a certain distance between the signal conversion board and the surface.
3. The sensitive glass bubble in the head of the pH probe should avoid touching the hard material. Any damage or scratches will cause the electrode to fail.
4. After completing the measurement, disconnect the pH probe from the signal conversion board. The ph analog sensor probe should not be connected to the signal conversion board without the power supply for a long time.
5. The bottle cap of the probe contains protective liquid (3.3mol/L KCL). Even if the bottle cap is screwed tightly, some protective liquid may still leak around the bottle cap, forming white crystals. But as long as there is still protective liquid in the bottle cap, it will not affect the life and accuracy of the probe. So please use it with confidence. It is recommended that the white crystals be poured back into the protective liquid in the bottle cap.
The Gravity: Analog pH Sensor / Meter Kit (SEN0161) and Gravity: Analog pH Sensor/Meter Kit V2 (SEN0161-V2) are intended for testing inaboratory environments only, and the probes are subject todata drift after extended measurements. If you need to measure a solution for an extended period oftime, we recommend using the Gravity: Analog pH Sensor / Meter Kit (SEN0161) or Gravity: Analog pH Sensor/Meter Kit V2 (SEN0161-V2).
  • 3.3~5.5V wide voltage input
  • Hardware filtered output signal, low jitter
  • Gravity connector and BNC connector, plug and play, no welding
  • The software library supports two-point calibration and automatically identifies standard buffer solution
  • Uniform size and connector, convenient for the design of mechanical structures
Signal Conversion Board (Transmitter) V2
  • Supply Voltage: 3.3~5.5V
  • Output Voltage: 0~3.0V
  • Probe Connector: BNC
  • Signal Connector: PH2.0-3P
  • Measurement Accuracy: ±0.1@25℃
  • Dimension: 42mm*32mm/1.66*1.26in
pH Probe
  • Probe Type: Laboratory Grade
  • Detection Range: 0~14
  • Temperature Range: 5~60°C
  • Zero Point: 7±0.5
  • Response Time: <2min
  • Internal Resistance: <250MΩ
  • Probe Life: >0.5 years (depending on the frequency of use)
  • Cable Length: 100cm
  • pH Probe(Laboratory Grade)  x1
  • pH Signal Conversion Board x1
  • Gravity Analog Sensor Cable x1
  • pH Standard Buffer Solution 4.0 x2
  • pH Standard Buffer Solution 7.0 x2
  • Waterproof Gasket x2
  • Screw Cap for BNC Connector x1
  • M3 * 10 nylon pillar x4
  • M3 * 5 screws x8
Niu.yx
Feb 11, 2025
Danli
Nov 08, 2024
Danli
Jan 25, 2024
Hydroponics Simulation Model
Projects Hydroponics Simulation Model
RosarIoT
Feb 24, 2023
DIY a pH Meter Using DFRobot pH Sensor and Transparent Display
Projects DIY a pH Meter Using DFRobot pH Sensor and Transparent Display
Frances
Jul 01, 2022
Thiago.Dias Nov 09, 2024
The sensor itself is great and I can take good measurements with it, but the buffer solutions that should help you calibrate it are pretty off, even if you shake the flask a lot. After calibrating it with my own solution it works great. Not giving 5 stars just because I expected the buffer solutions to actually work.
HIDJO.Herve Mar 15, 2024
Thank You DFROBOT i receive my order last day and i am verry happy
Cihan. Nov 07, 2023
Great pH Sensor kit, you can use with your small applications, if you want industrial version you can find on dfrobot related category.
Only 2 Left
$39.50
