5'' 800x480 IPS Raspberry Pi DSI Touchscreen(Compatible with Raspberry Pi 3B/3B+/4B)
$44.90
SKU: DFR0550
Purchase this product and earn 449 reward points, which are tied to VIP membership program. Learn More >
This is a 5" Raspberry Pi LCD touchscreen with 800*480 resolution and 108×64.8mm display area. The product supports Raspberry Pi DSI display interface and comes with a capacitive touch panel on its screen and supports 5 touch points.
DFR0550-Raspberry Pi Display
The special holes design on the back of the screen is convenient to directly install the Raspberry Pi in the product. There is no need to provide external power for the touchscreen as the Raspberry Pi power supply is adopted. In addition, the screen supports hardware backlight adjustment. The function can be realized by turning the potentiometer on the back of the display.
DFR0550-Raspberry Pi Touchscreen
  • Capacitive Touchscreen, Support 5 TouchPoints.
  • Raspberry DSI Direct Driver
  • Operating Voltage: 3.3V (Supplied by Raspberry Pi display interface)
  • The Maximum Operating Current: 320mA
  • Screen-off Current: 100mA
  • Resolution: 800*480
  • Video Interface: Raspberry Pi DSI
  • Number of Touch Points: 5
  • Viewing Angle: 80°/80°/80°/80°
  • RGB888-16 Mega True Color
  • Refresh Frequency: 60Hz
  • Luminous Efficiency: 550 cd/㎡
  • Operating Temperature: -20℃~70℃
  • Dimension: 121mm×76mm / 4.76" × 2.99"
  • Mounting Hole Size: M2.5
  • Outside Mounting Hole Position: 113mm × 68mm/ 4.45" × 2.68"
  • Inside Mounting Hole Position: 58mm x 49mm/ 2.28" x 1.93"
  • 5'' TFT-Display with Touchscreen(V1.0) x1
  • FFC cable 45mm pitch 1.0mm-15pin x1
  • M2.5*8 Standoffs x8
  • M2.5*6 DK4.9 Machine Screws x8
Touch Cam - A Raspberry Pi Camera
Projects Touch Cam - A Raspberry Pi Camera
Mukesh Sankhla
Nov 08, 2024
Grammatizator, fiction writing assisted by ChatGPT
Projects Grammatizator, fiction writing assisted by ChatGPT
RoniBandini
Jan 28, 2024
Ron. Feb 04, 2021
These displays are perfect for our product. The display is bright and clear. The touch screen works reasonably well.
Hugo. Nov 20, 2020
L'emballage du produit était parfait. Arrivé en temps et en heure. Je n'hésiterais pas à repasser commande ici.
Only 5 Left
$1.70
