ABS Transparent Case for Arduino UNO R3
$3.90
SKU: FIT0603
This is a transparent plastic Arduino case, which is specially designed for Arduino UNO R3. It is made of ABS material, which has good strength and tenacity. We have reserved enough GPIOs slots on the case, makes it convenient to connect sensors and modules on the board. It will prevent dust and droplets-splashing, avoid pin exposure and solder joint short circuit and so on. In addition, the top and bottom of the case are designed as splicing structures that are compatible with LEGO. You can build a lot of creative projects with LEGO parts.
Note: This product does not include a Arduino UNO R3.
  • Attractive Appearance
  • Easy to mount and dismount
  • LEGO Compatible
  • Material: ABS Injection
  • Apply to Arduino/DFRduino UNO R3 microntrollers
  • Dimension: 79×60×22mm/ 3.11×2.36×0.87”
  • ABS Transparent Case for Arduino UNO R3 (Lego Compatible)               ×1
  • Screw set    ×1
Tim. Jan 24, 2021
This is such a cool little enclosure! This impulse buy was initiated by virtue of it being lego-compatible: as such I decked it out with part of a lego set that I got for Christmas... Star Wars Episode III of course! Next on the list is to incorporate a lego builder set to build something functional, with motors and gears, as I assume was the intention behind this product.
