Beetle ESP32 Microcontroller
$9.90
SKU: DFR0575
  • $9.70 2+ items
  • $9.50 5+ items
  • $9.20 10+ items
Is FireBeetle ESP32 IoT Microcontroller too big for your projects? Why not try our newly launched Beetle-ESP32. This Beetle-ESP32 Microcontroller of 1.38”×1.34” small size is a simplified version of FireBeetle ESP32 IoT Microcontroller and specially designed for electronic engineering fans and DIY lovers. It is equipped with 4 analog ports, 4 digital ports, UART and I2C interfaces, which would be a perfect replacement of FireBeetle ESP32 IoT Microcontroller.
This microcontroller enables users to directly burn programs via the on-board USB interface. Meanwhile, Bluetooth and WIFI are integrated in the microcontroller for supporting more applications. With this Beetle-ESP32, you can easily build up your dreaming project.
  • A small size of 35mm×34mm
  • Enable users to directly download and debug programs through Micro USB, free from programmer.
  • Large-scale I/O ports with gold plating, easy to screw wire on it or to sew the board on the clothes with wires, no need to solder.
  • A group of gold plating power interfaces of honeycomb type, convenient to use.
  • Integrate WIFI and Bluetooth
  • USB Supply Voltage: 5.0V
  • VIN Supply Voltage: DC 3.5-6.5V
  • Processor: Tensilica LX6 dual-core processor (One for high speed connection; one for independent programing)
  • Frequency: 240MHz
  • SRAM: 520KB
  • Flash: 16Mbit
  • Wi-Fi Standard: FCC/CE/TELEC/KCC
  • Wi-Fi Protocol: 802.11 b/g/n/d/e/i/k/r(802.11n, high speed can reach to 150 Mbps),  converge A-MPDU and A-MSDU, supporting 0.4us protecting interval.
  • Frequency Range: 2.4~2.5GHz
  • Bluetooth Protocol: comply with BR/EDR/BLE standard of Bluetooth v4.2.
  • On-chip Clock: 40MHz crystal and 32.768 KHz crystal
  • Digital Interface: D2, D3, D4, D7
  • Analog Interface: A0, A1, A2, A3
  • I2C: 1
  • Serial Port: 1
  • Dimension: 35×34mm/1.38×1.34"
  • Beetle ESP32 Microcontroller               x1
ESP32 cpplinq Tutorials Menu
Blog ESP32 cpplinq Tutorials Menu
Apr 25, 2021
Blog ESP32 HTTP server Tutorials Menu
Apr 25, 2021
ESP32 Soft AP Tutorials Menu
Blog ESP32 Soft AP Tutorials Menu
Apr 25, 2021
ESP32 MicroPython Tutorials Menu
Blog ESP32 MicroPython Tutorials Menu
Apr 01, 2021
ESP32 Arduino Tutorials Menu
Blog ESP32 Arduino Tutorials Menu
Apr 20, 2021
250+ Must-read Tutorials for Learning ESP32 and Arduino
Blog 250+ Must-read Tutorials for Learning ESP32 and Arduino
Apr 29, 2021
yossi.wurmbrand Sep 23, 2023
working great, better the esp32 in Aliexpress.
