64x32 Flexible RGB LED Matrix-4mm Pitch
$79.00
SKU: DFR0595
Flexible 64x32 RGB LED Matrix with 256x128mm dimensions. Requires external power and high-speed microcontrollers, compatible with Raspberry Pi.
Purchase this product and earn 790 reward points, which are tied to VIP membership program. Learn More >
If you have tried our 64×64 or 64×32 RGB LED Matrix Panel, but you had to give up some of your original ideas and designs out of the limitation of thickness and weight of the product, why not try this 64 ×32 flexible RGB LED Matrix. I assure you it will be an excellent choice for you. With a size of 256×128mm and flexible feature, it can almost meet all your needs.
Please don’t bend the product over 30° or repeatedly bend it in case causing product damage. In addition, same as normal matrix panel, this screen also cannot work with Uno board. We recommend using microcontrollers with large RAM and high speed to control the LED such as Raspberry Pi, Mega 2560 etc. The LED matrix has two IDC connectors (DATA_IN, DATA_OUT) on the back, which enable you to cascade multiple panels and make a huge screen. Please provide external power supply for the LED matrix during operation, otherwise the screen display will be unclear or incomplete.
  • Pixel Pitch: 4mm
  • Operating Voltage: 5V
  • Maximum Power Consumption: 18W
  • Repetition Frequency: ≧60Hz
  • Refresh Frequency: ≧300Hz
  • Viewing Angle: ≧160°
  • Resolution: 64x32=2048Dots
  • Optimal Visual Distance: 4-30M
  • Dimension: 256x128mm/10.08x5.04”
  • 64x32 Flexible RGB LED Matrix-4mm Pitch               x1
  • IDC to XH2.54 Cable      x1
  • IDC to IDC Cable          x1
  • Power Supply Cable       x1
Out Of Stock
