"Yuewalker"-Tracked Chassis (Black)
$75.00
SKU: ROB0154
An agile tracked chassis with high-strength aluminum base offers stability and durability. Ideal for DIY robot cars, compatible with Arduino and sensors. Unassembled kit.
Purchase this product and earn 750 reward points, which are tied to VIP membership program. Learn More >
This is Yuewalker, an agile tracked chassis, low noise and easy to control, which could be a good partner for your tank-liked robots. High-strength aluminium alloy tank base, with delicate appearance, higher stability and longer durability.
The track robot is made of engineering plastic that basically assured the good elasticity, excellent damping effect and large road grip of the product. What’ s more, it comes with two quality motors to provide high power and speed, which enables your DIY robot car to widely suit all kinds of road surfaces.
To find more interesting functions, you can use this tracked chassis with Arduino microcontrollers or add other electronic components on the base such as, IR sensor, ultrasonic sensor, camera, LED, display, WIFI module, etc. For Arduino fans and smart robot car lovers, this can be a good choice for you!
Note: the tracked chassis is unassembled, you need to get it done by yourself.
Install Instruction:
"Yuewalker"- Tracked chassis ROBOT UNBOXING
  • Package includes:
  • Base: 1 set
  • Motor: 2
  • Track: 2
  • Drive Wheel: 2
  • Driven Wheel: 10
  • Screw Accessory: 1 set
  • Wrench: 1
  • Screwdriver: 1
  • Motor parameter:
  • Input Voltage: 12V
  • Rotation Speed: 160RPM
    • "Yuewalker" - Tracked Chassis x1
    Joseph. May 06, 2022
    Powerful and with room to spare, this chassis has great attachment slots. Whether you're attaching directly or making a spacer or adapter, the spaces on the chassis make the job easier.
    Only 14 Left
    $19.90
