Titan Case for LattePanda 2 Alpha&Delta (NOT Compatible with LattePanda 3 Delta 864)
$19.00
SKU: FIT0550
  • $18.43 3+ items
  • $18.00 5+ items
  • $17.48 10+ items
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
Dedicated Design, Superior Texture
Titan case uses conflict aesthetics to combine functional design considerations with sci-fi elements. Understated color selection and layered surface treatment technology create a kind of design, flat but with unlimited potential.
Titan Case for LattePanda Alpha&Delta
Two Models, Balancing Extensibility And Integrity
Invisible quick-release cover design. A complete computer after fastening, or an open hardware development platform after quick disassembling.
Perfect Protection
High-strength engineering plastic effectively protects the internal precise electronic components from accidental falls and static damage in a complex development environment.
Note:
1. Titan case is designed for LattePanda 2 Alpha & 2 Delta, not compatible with LattePanda V1.0 and LattePanda 3 Delta.
2. Use M4 screws for the two middle holes in the bottom case, and make sure to control their length to avoid using screws that are too long, as they could damage the PCB when fully tightened. The maximum length for screwing from the outside of the shell to the inside is 5mm; screws that are 7mm long will touch the PCB. If you're mounting the case onto a device with a thickness of 'a' mm, the maximum screw length you should use is (a+5) mm.
  • Protect components
  • Easy to assemble
  • All interface reserved
  • Compatibility: LattePanda Alpha & Delta
  • Material: ABS+PC
  • Dimensions: 120*87*26 mm/4.7*3.4*1.0 Inch
  • Weight: 100g
  • Titan case x1
  • M3 screws x6
 LattePanda Delta Projects Overview
Blog LattePanda Delta Projects Overview
May 30, 2022
Dale.Marcell Feb 06, 2020
This is a nicely designed case that’s very easy put together. The cover as access panels to get at the GPIO headers on both sides of the board. Plenty of room at the bottom for the Wi-Fi / Bluetooth antennas. You can also mount your M.2 devices in the same will vented bottom panel. The power button on the side makes it very easy to power up you unit. The power on LED’s are placed on the other side marking it easy to see if you board is powered up. As a Alpha user I highly recommend this case!
jérémi.darien May 10, 2025
This is an amazing product
Alex.Schwandt Jan 16, 2021
The good quality and design of the case is practical in usage, allowing easy acess to the GPIO's. This case is best what i have see for the LP.
