7 inches Touch Display (eDP) for LattePanda 3 Delta / LattePanda 2 Alpha / LattePanda 2 Delta
$79.90
SKU: FIT0551
  • $77.60 3+ items
  • $76.00 5+ items
  • $74.00 10+ items
Purchase this product and earn 799 reward points, which are tied to VIP membership program. Learn More >
Excellent Visual Effect
This display adopts IPS screen technology, supports a 178-degree visual Angle, 1024 x 600 high resolution, and high color saturation, achieving excellent picture.
Designed For HMI and Portable Projects
We have made many product design optimizations for HMI and portable project requirements. For example, HMI scenarios are often complex and dusty, but this display uses a fully fit design to perfectly prevent dust from entering the screen, and also effectively reduces the reflection of light. In order to make the screen easy to be installed, the screen edge comes with special double-sided adhesive tape, which can be easily and firmly fixed.
Best Compatibility
Unlike other normal HDMI screens, this display uses an eDP interface and has the best compatibility with LattePanda 3 Delta & 2 Alpha & 2 Delta (not compatible with LattePanda V1.0).
  • 1024 x 600 high resolution
  • Capacitive screen
  • Transmittance:85%
  • Surface Hardness: 6H
  • Response Time: ≤16ms
  • Tapping Durability: 200,000,000 times
  • Supports LattePanda 3 Delta / LattePanda 2 Alpha / LattePanda 2 Delta Single Board Computer
  • Connector: 10cm FPC Extension Cable
  • Dimensions: 180*110*5 mm / 7.1*4.3*0.2 inches
  • 7”eDP Touch Display x1
  • 30pin eDP cable x1
Julian.van Hemert Feb 16, 2025
Amazing screen, works well. I do miss a way to screw it on a surface though, but I guess that should be quickly resolved.
Alex.Schwandt Jan 16, 2021
The touch display has a good sensitivity, resolution for good readability and is fast. It was easy to connect and it worked out of the box. I can recommand to use it, since in experimantal applications no stationary display is needed and the price is totally fine.
Daniel Augusto. Apr 06, 2020
Hace poco inicie un proyecto de construccion de un Mini PC con la Board Lattepanda DELTA, un mini pc muy potente, esta vez les voy a mostrar como adaptarle la pantalla Touch Display(eDP) de solo 7 pulgadas, pero con buena resolucion y tactil para sacarle mas provecho al mini pc. https://youtu.be/aqlssO9TPkM
$259.00
