Please don’t bend the product over 30° or repeatedly bend it in case causing product damage. In addition, same as normal matrix panel, this screen also cannot work with Uno board. We recommend using microcontrollers with large RAM and high speed to control the LED such as Raspberry Pi, Mega 2560 etc. The LED matrix has two IDC connectors (DATA_IN, DATA_OUT) on the back, which enable you to cascade multiple panels and make a huge screen. Please provide external power supply for the LED matrix during operation, otherwise the screen display will be unclear or incomplete.
Compared with Flexible RGB LED Matrix-4mm Pitch, this matrix screen has larger Pixel pitch and areas.
Nov 03, 2022
Pros: Lightweight, very bright, compatible with standard matrix controllers Cons: Fragile, and won't come with .rcvbp configuration files (you'll have to trial and error to create them yourself if you want to use a controller that requires it).
Nov 20, 2020
L'emballage du produit était parfait. Arrivé en temps et en heure. Je n'hésiterais pas à repasser commande ici.
